00 Si using oil & smokes on takeoff
Old Feb 19, 2005 | 09:41 AM
sfbu1's Avatar
Default 00 Si using oil & smokes on takeoff
This is the wifes car and just rolled 70k. Using about 1 to 1 1/2 qt per 3-4k miles and light smoke on take off. If I accelerate fast will leave a fairly dark cloud. I have used mobil 1 5w30 and premium gas since new. no real hard driving, mostly commuter use. Any ideas why the smoke/oil usage. Could plugs, valves out of adjustment cause this or is it deeper?
Old Feb 19, 2005 | 09:48 AM
Archidictus's Avatar
Unceasing Measure
Default Re: 00 Si using oil & smokes on takeoff (sfbu1)
Could be bad rings or cracked ringlands or bad valve seals in the head. It's also possible that the seals on the spark plug tubes are shitting out on you and oil's trickling into the combustion chamber from there.
Is the smoke black or blue? Oil smoke is blue.
My advice is to pull the plugs, check for oil or residue on them and then pull the valve cover and see how all the gaskets are doing. If there's nothing immediately evident after you do that, it's probably the pistons or the valves. That's a lot of oil use for a Honda, so you're right in bringing it to our attention now.
Good luck
Old Feb 19, 2005 | 11:05 AM
HitEm'Up's Avatar
Go ahead pull the plugs and see what they look like that will tell you alot of whats going on
91 Wagon
Apr 6, 2018 03:34 AM
WanaBeFaster
May 6, 2007 08:17 AM
Jax4gencivic
May 4, 2006 07:59 AM
preludeguy_92
Jun 25, 2005 11:39 AM
