what suspension are you using on ur teg
Old Feb 19, 2005 | 09:12 AM
ssrcx94's Avatar
Default what suspension are you using on ur teg
just curious to everyones setup
Old Feb 19, 2005 | 09:38 AM
kevin85193's Avatar
Default Re: what suspension are you using on ur teg (ssrcx94)
Coming in the mail koni yellows/ground control coilovers
Old Feb 19, 2005 | 09:40 AM
jspec-integ Ls's Avatar
Default Re: what suspension are you using on ur teg (kevin85193)
kyb agx w/ skunk 2 coilovers
Old Feb 19, 2005 | 11:21 AM
95LSDOHC's Avatar
Default Re: what suspension are you using on ur teg (jspec-integ Ls)
tein flex
Old Feb 19, 2005 | 11:34 AM
NightmareApex's Avatar
Default Re: what suspension are you using on ur teg (95LSDOHC)
tien ss, jic camber plates(i use to own some jic coilovers so i kept the plates, but the jic's suck) s/t sway bars, itr LCA, modified subframe, custom 6 point roll cage, and a few home made bars.
Old Feb 19, 2005 | 01:02 PM
FR-MOB: ThE bEe GuY's Avatar
Default Re: what suspension are you using on ur teg (NightmareApex)
Skunkworks coils and Tokico illuminas, SPC balljoints in the front, new bolts and washers in the back
Neuspeed front upper strut bar, Ebay rear upper strut bar, tie bar, and C pillar bar.
I might try the Omni coilovers soon though, heard good stuff about them
Modified by ThE bEe GuY at 2:57 PM 2/19/2005
Old Feb 19, 2005 | 01:17 PM
Pythagoras's Avatar
Default Re: what suspension are you using on ur teg (ThE bEe GuY)
Omni Power Coilovers
Omni Power Rear LCA's
Omni Power Front and Rear Camber Kit
Spoon Front and Rear Tower Bars
BLOX Rear Sway Bar
Old Feb 19, 2005 | 01:21 PM
Avenged7x's Avatar
Default Re: what suspension are you using on ur teg (Pythagoras)
putting on h&r race springs with kyb agx today
Old Feb 19, 2005 | 01:29 PM
timmy8151's Avatar
Default Re: what suspension are you using on ur teg (Avenged7x)
ITR Rear Sway Bar
H&R OE springs
KYB AGX shocks
Old Feb 19, 2005 | 01:39 PM
GG-SquadDB's Avatar
Default Re: what suspension are you using on ur teg (timmy8151)
Illumina GC combo ITR sway to follow
Old Feb 19, 2005 | 01:49 PM
intougera's Avatar
on my 96 ls ive got: tein ss dampers, tanabe f&r strut tower bars, tanabe f&r chassis braces, skunk2 arms, zspeed links in the rear, itr 22mm swaybar, beaks subframe reinforcement, and an autopower race 4pt rollcage tightens it up, rota slipstreams with 205/50/15 kumho 712's. i like
Old Feb 19, 2005 | 01:50 PM
SonicBlueTeg's Avatar
--Front
Tein RA
stock strut/sway bar
--Rear
ITR rear lower control arms
Tein HR
J's cpillar bar
ITR rear strut tower bar
22mm sway bar
Comptech rear sway
Old Feb 19, 2005 | 01:59 PM
aznballer's Avatar
stock struts and neuspeed race springs
Old Feb 19, 2005 | 02:21 PM
IntegraBoy04's Avatar
Default Re: (aznballer)
Tein RE
Neuspeed Strut bar
Type R 22mm sway bar
Type R lcas
Falken Azenis (overrated)
Old Feb 19, 2005 | 02:26 PM
Spoon ITR's Avatar
Default Re: (IntegraBoy04)
KYB AGX's
Eibach Prokit (soon to be changed to ?? )
Cusco front strut bar
Cusco rear strut bar
Old Feb 19, 2005 | 02:29 PM
sabotage7's Avatar
Default Re:
koni yellows
GC coilovers
skunk2 camber kit
Old Feb 19, 2005 | 02:58 PM
daLixz25's Avatar
itr lcas
itr spec koni yellows
eibach sportlines
itr rear swaybar
advanced chassis innovations lower tie bar
215/45/16 yokohama es100s
Modified by daLixz25 at 4:51 PM 2/19/2005
Old Feb 19, 2005 | 03:00 PM
dawalude's Avatar
Default Re: (daLixz25)
tokico springs and stock shocks
Old Feb 19, 2005 | 03:13 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
H&R Sport springs
KYB AGX shocks
KYB strut mount bushings
KYB dust seals/bumpstops
Energy Suspension master kit
SPC front upper balljoint camber kit
SPC rear upper arm camber kit
OEM lower balljoints
OEM trailing arm bushings
OEM tie rods
Old Feb 19, 2005 | 04:57 PM
eymnewdc4's Avatar
Default Re: (MugenDude)
all stock.
going for KYB AGX and H&R sports.
from there .... who knows?
royalrebel
Nov 9, 2008 04:05 PM
Da La Soul
Feb 2, 2007 09:18 PM
nc_mx_kid
Nov 23, 2004 08:53 PM
Hybrid CRX
Oct 21, 2004 06:56 AM
street-trendz
Feb 23, 2003 10:03 AM
