Q:flexible aluminium pipe for air filter
Old Feb 19, 2005 | 08:02 AM
RACEPAK's Avatar
Default Q:flexible aluminium pipe for air filter
hello everybody...
what do you guys think about routing the air filter from the turbo with flexible aluminium pipe ?
i tried to burn it like 10sec's on the stove in my house to see how it reacts to heat and nothing happened to it.
Old Feb 19, 2005 | 08:09 AM
Curtisbeef's Avatar
Is that the stuff made for dryers?
i dont think that will hold the vacume of the inlet.... there made of like tinfoil...
Old Feb 19, 2005 | 08:12 AM
RACEPAK's Avatar
Default Re: (Curtisbeef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curtisbeef &raquo;</TD></TR><TR><TD CLASS="quote">Is that the stuff made for dryers?
i dont think so...
i got it from a auto part shop.
Old Feb 19, 2005 | 08:20 AM
mrbsponge's Avatar
i know there is some high grade flexible aluminum that is used for turbos inlets, you see it alot on rx7s with big turbo inlets, but i am not sure if that is it?
it is a little hard to secure and if its the flimsy **** may end up coming loose and falling into something vital.
give it a shot, let us know
Old Feb 19, 2005 | 09:02 AM
90civichbsi's Avatar
Default Re: (mrbsponge)
i was actually planning on using the same thing temporarily when i install my turbo setup. Im talking about the dryer stuff, its aluminuim but it could easily hold the vacuum of a turbo inlet
Old Feb 19, 2005 | 09:04 AM
beepy's Avatar
It's definately dryer ducting. Not going to collapse under the negligible vacuum, but not going to support any load either.
Old Feb 19, 2005 | 10:58 AM
MooreBoost's Avatar
Default Re: (beepy)
I would rather put the filter directly on the turbo.
Old Feb 19, 2005 | 11:39 AM
miro_gt's Avatar
Default Re: (MooreBoost)
the pipe is just like the ones for use on dryers but smaller ... there are even a couple of different type pipes, but yours looks like the good one - there are some that unfold themselves easily and you don't want some of those; so you can use silicon (a lot) to provide vacuum ability, as well as put some metal rings outside to make it strong. ... but I think it would work .. at least, that's what I was planning to use until I get my intercooler pipping ... was even thinking of pvc pipes
Old Feb 19, 2005 | 01:37 PM
Boltz's Avatar
Default Re: (miro_gt)
RS akimoto has flexible dryer looking pipe that is actually very sturdy that I use for my intake and for an air guide to the intake.
works well for me
Old Feb 19, 2005 | 02:56 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost &raquo;</TD></TR><TR><TD CLASS="quote">I would rather put the filter directly on the turbo.</TD></TR></TABLE>
same here
Old Feb 19, 2005 | 03:07 PM
SPOOLINmatt's Avatar
Default Re: (wantboost)
im using the "flex-o-pipe" **** from autozone or advance auto. its like 16inches long that you get...i had to go to a muffler shop to get a section of 3" though because the parts stores dont carry that size and i have an sc61. this stuff is made for exhaust repair.
Old Feb 19, 2005 | 05:14 PM
jfoster's Avatar
Default Re: Q:flexible aluminium pipe for air filter (RACEPAK)
How sturdy is it? Cause I would mainly be worried that under full spool the turbo would suck on it hard enough to crunch it in like a pop can. Which would be really bad as it might then eat it
Old Feb 19, 2005 | 05:29 PM
mattcalica's Avatar
i dont know how you would clamp a filter to that thing. I mean, if its flexible, it would just crush the piping if you tried to clamp down the filter...right?
Old Feb 19, 2005 | 08:33 PM
Default Re: Q:flexible aluminium pipe for air filter (jfoster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfoster &raquo;</TD></TR><TR><TD CLASS="quote">How sturdy is it? Cause I would mainly be worried that under full spool the turbo would suck on it hard enough to crunch it in like a pop can. Which would be really bad as it might then eat it </TD></TR></TABLE>
the **** im talking about is strong. you can squeeze it, push down on it, whatever. its as strong as the regular piping. go clamps on it and everything.
Old Feb 19, 2005 | 09:30 PM
adictionbass's Avatar
Default Re: Q:flexible aluminium pipe for air filter (SP00LIN)
just because something is flexible laterally doesnt mean it is flexible vertically.
pcguy760
Oct 16, 2008 07:02 PM
dannydos
Jun 26, 2005 06:50 AM
GSRerrr
Dec 13, 2004 11:34 PM
Tinker219
Apr 23, 2003 01:22 PM
ezark
Jan 6, 2002 11:22 AM
