hasport mounts problem
Old Feb 19, 2005 | 07:28 AM
civicguy's Avatar
Default hasport mounts problem
trying to get the hasport hydraulic kit on my ef ,i cant get any of the brakets in the back to work,even the one they recomend to use,i got 90-93 integra 94 up integra and on from the 99-00 si,none of them fit its like 3"away from the mount
Old Feb 19, 2005 | 08:04 AM
brian g's Avatar
Default Re: hasport mounts problem (civicguy)
The 90-93 is the correct one, post a picture and I'll tell you if it's the right one.
brian g
Old Feb 19, 2005 | 08:16 AM
civicguy's Avatar
Default Re: hasport mounts problem (brian g)
Old Feb 19, 2005 | 08:27 AM
Dragline's Avatar
3" off from front to back or from side to side?
Old Feb 19, 2005 | 08:32 AM
whiterex's Avatar
Are u sure you have the rear mount bolted to the right holes? There are two different sets of holes that you can bolt it in to. You want the ones closest to the drivers side
Old Feb 19, 2005 | 08:33 AM
civicguy's Avatar
Default Re: (whiterex)
yup right there and still like 2"from it
Old Feb 19, 2005 | 09:49 AM
hahagasdcrx's Avatar
Default Re: (civicguy)
did you move the mount on the rear crossmember to the next set of holes? Is your alternator hitting the bdy?
Old Feb 19, 2005 | 10:15 AM
civicguy's Avatar
Default Re: (hahagasdcrx)
the mount on the back is on the holes closest to the driver side,the alternator is not hitting the body,do i have the right braket?thats my question
Old Feb 19, 2005 | 11:15 AM
crxtreme89h's Avatar
Looks like the correct bracket to me. Did you dent the lip down on the crossmember you are bolting it to?
Old Feb 19, 2005 | 01:00 PM
civicguy's Avatar
Default Re: (crxtreme89h)
i did dent the crossmember,i have done many swaps this the first time this happens to me,now it looks like the correct braket but if read the instruction it says that you have to modified the braket to accept the 19mm bolts,on this one they go in without no modifications,and it looks exactly like the one hasport got in their web site
Old Feb 19, 2005 | 02:53 PM
civicprojectPR's Avatar
hi sorry i cant help u with the mounts i only want to know if are from Puerto Rico
Saludos
Old Feb 19, 2005 | 03:11 PM
civicguy's Avatar
Default Re: hasport mounts problem (civicprojectPR)
yup de anasco,be there on the 14th
Old Feb 19, 2005 | 06:51 PM
me too man am from gurabo but what is going to happend in Anasco in 14???
Old Feb 19, 2005 | 07:02 PM
brian g's Avatar
It appears to be right, I need a picture of the engine in the car with the left and right mounts hooked up. Obviously there's a problem, but there shouldn't be.
brian g
Old Feb 20, 2005 | 09:16 AM
civicguy's Avatar
wetodd its not working right now,but i will get them to asap
Old Feb 20, 2005 | 02:36 PM
civicguy's Avatar
got it fix,i had the wrong braket
Old Feb 20, 2005 | 02:46 PM
Crx Jimmy's Avatar
make sure you have the new style hasport mounts the hydro conv wont work with their old steel mounts
Old Feb 20, 2005 | 09:00 PM
brian g's Avatar
Default Re: hasport mounts problem (dragline)
The bracket you have pictured looks like a 94 integra bracket. The 90-93 Integra bracket is shorter and the offset goes the opposite direction.
brian g
Jul 25, 2007 01:41 PM
CornerCarvin
May 6, 2007 09:01 AM
Adam.
Nov 1, 2004 02:00 PM
Runnerdown
Oct 4, 2004 06:20 PM
Got Utensils
Mar 18, 2004 05:08 AM
