Reset Check Engine Light
Search in the future. For maint. Require light you put your key in the button on the cluster. For the CEL there is a button below the underside of the dash, even below the steering wheel. Thats where it is on Tegs I dunno about accords. Someone help us out
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeIsCool »</TD></TR><TR><TD CLASS="quote">Search in the future. For maint. Require light you put your key in the button on the cluster. For the CEL there is a button below the underside of the dash, even below the steering wheel. Thats where it is on Tegs I dunno about accords. Someone help us out
There is no button on the accords. You have to pull a fuse from the box under the hood (don't remember which one) to reset the ecu.
</TD></TR></TABLE>There is no button on the accords. You have to pull a fuse from the box under the hood (don't remember which one) to reset the ecu.
saanemon
May 28, 2003 10:12 PM
