XSI motor ??
Old Feb 18, 2005 | 11:13 PM
davidcrx89's Avatar
Default XSI motor ??
how do you know if it is an XSI motor?
Old Feb 18, 2005 | 11:35 PM
hahagasdcrx's Avatar
Default Re: XSI motor ?? (davidcrx89)
xsi motor has 1xxxxxxx under the B16 on the engine block. SiR would be B16 5xxxxxxx.
Old Feb 18, 2005 | 11:40 PM
davidcrx89's Avatar
Default Re: XSI motor ?? (hahagasdcrx)
sir is a crx and xsi is integra right so which is better or are they the same?
Old Feb 18, 2005 | 11:45 PM
pretty much the same motor, depending on year. Also many tranny options between the two.
Old Feb 19, 2005 | 12:24 AM
Burlyirishdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahagasdcrx &raquo;</TD></TR><TR><TD CLASS="quote">xsi motor has 1xxxxxxx under the B16 on the engine block. SiR would be B16 5xxxxxxx.</TD></TR></TABLE>
i think it's the other way around....i thought xsi/Rsi was the 5 mil series and the Si-R was the 1 mil series.
Old Feb 19, 2005 | 07:08 AM
hughesl's Avatar
The tranny options are different for each, motors the same.
You get better gearing on the xsi, but standard lsd is not an option, like it is on the sir.
I got the xsi with s1 tranny and then installed a quaife lsd.
Old Feb 19, 2005 | 07:20 AM
crxgator's Avatar
Default Re: XSI motor ?? (hughesl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hughesl &raquo;</TD></TR><TR><TD CLASS="quote">The tranny options are different for each, motors the same.
I got the xsi with s1 tranny and then installed a quaife lsd.</TD></TR></TABLE>
i thought you can get the ys1 with lsd off of a jdm integra?
Old Feb 19, 2005 | 09:23 AM
hughesl's Avatar
Default Re: XSI motor ?? (crxgator)
You can get the ys1 with lsd but was that off of the xsi?
Old Feb 19, 2005 | 09:54 AM
Default Re: XSI motor ?? (Burlyirishdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude &raquo;</TD></TR><TR><TD CLASS="quote">i think it's the other way around....i thought xsi/Rsi was the 5 mil series and the Si-R was the 1 mil series.</TD></TR></TABLE>
DA6 DA8 "B16A 1xxxxxx" PR3 '88-91 S1 or J1
Cable type Clutch 160 10.2:1
EF8 EF9 "B16A 5xxxxxx" PR3 '89-92 Y1 or YS1
Cable Optional 'LSD' stamp on casing 160
10.2:1
89CRXSi_24
Mar 26, 2011 06:20 PM
bmoua
Aug 28, 2007 03:04 PM
isaacson06
Aug 25, 2007 09:14 AM
Rustyman14
Jul 7, 2005 04:24 PM
InevitableRace
16
May 20, 2002 01:27 PM
