OEM Honda clutch fluid vs. regular brake fluid
Does anyone know if there is any difference between the two when using it for the clutch system? Would the different fluid make the clutch feel softer/firmer?
Clutch fluid and brake fluid are one and the same. So...any DOT3/DOT4 fluid will work for either system. There shouldn't be a difference.
Personally I use synthetic DOT4 and bleed once a year.
explictness
Feb 21, 2007 08:37 PM
