Test Pipe of Hi flow cat?
Old Feb 18, 2005 | 09:17 PM
JDM00SI's Avatar
Default Test Pipe of Hi flow cat?
sup,
im currently in the process of getting rid of my stock cat. im running a comptech 4-2-1 header, and apexi. will a high flow cat make as much power as the test pipe? mainly my plan it so route my header to either a test pipe or high flow cat and then the apexi cat-back. is there a way to bore my stock cat?
- i was also told that i will loose much torque, when will noticable power gains be felt after this modification?> i was told higher speeds, does that mean i will feel power after 40mph? or in the high rpms? ?????
thanks alot
Old Feb 18, 2005 | 09:30 PM
JDM00SI's Avatar
Default Re: Test Pipe of Hi flow cat? (bigbeasta4)
i was also told a test pipe gives a rotten egg smell to the car..... am i correct?
Old Feb 19, 2005 | 06:02 AM
Padawan's Avatar
Darth ModerVader
The performance difference between a test pipe and a quality high-flow cat on your application will be negligible. The smell that results from running a test pipe isn't a "rotten egg" smell, the best I can describe it as is a heavy exhaust fume smell. I'd suggest contacting Dave of SMSP about one of his new spun-bodied cats.
Old Feb 19, 2005 | 08:18 AM
JDM00SI's Avatar
Default Re: Test Pipe of Hi flow cat? (Padawan)
thyey both give same amoutn of power right?
is there a way to just bore my stock cat?
thanks
Old Feb 19, 2005 | 08:57 AM
Padawan's Avatar
Darth ModerVader
In your situation, both a test pipe and the SMSP cat I mentioned above would yield similar gains. I wouldn't recommend gutting your existing cat, because the turbulence generated inside once the catalyst is removed can have negative effects on performance.
Old Feb 19, 2005 | 11:06 AM
Jose-aka-Pedro's Avatar
I recently replaced my cat with a Test pipe, see sig for my car.
and its smells like somebody poured gas all around my car when I rev it etc..., even freinds have asked why such the heavy smell of gas
The test pipe ( With mine) will make your exhuast sound choppy,
Dout i hepled but thats what mine did, I am even thinking of going to back a cat or a hi-flow cat cuz the exhuast sounds ricer
Old Feb 19, 2005 | 10:21 PM
JDM00SI's Avatar
Default Re: Test Pipe of Hi flow cat? (Street_Racer)
what kind of high flow cat would you perfer on my b16? thanks
Old Feb 20, 2005 | 12:22 AM
PrettyLude's Avatar
car sound
Old Feb 20, 2005 | 05:12 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbeasta4 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of high flow cat would you perfer on my b16? thanks</TD></TR></TABLE>
With Dave's recent testing completed, I'd now go with an SMSP spun-bodied cat. They've proven to flow quite a bit better than the Car Sound's he was previously using, they're metal substrate, and the pricing remains basically the same as the old Car Sound.
Old Feb 20, 2005 | 06:42 PM
JDM00SI's Avatar
will a hi flow cat backfire?
thanks
PurpleAccord88
Feb 3, 2007 08:32 PM
DpQInteg
May 13, 2006 07:40 AM
aemintgsr
Jan 10, 2005 12:18 PM
808State
May 14, 2002 11:12 AM
00PurpleGSR
Apr 13, 2002 03:29 PM
