transmission not disengageing!!!!!
Old Feb 18, 2005 | 09:07 PM
ALL IMPORT's Avatar
Default transmission not disengageing!!!!!
heres my problem i just got the trans re-built. its got a new stage 2 clutch (second clutch i got to tryto fix the problem) new lsd quaif. it has now come to my attention that it must not be the clutch cause it still aint fixed. the symptoms are if i push the clutch in & hold ( not rolling with the shifters in nutral) start the car it runs, let the clutch out it stalls out. if i reve the motor a little when i let the clutch out it will not stall & idle. also if i push the clutch in & hold it in, then put it in any gear the car will not roll still cause somethng stops the car as if the brake is on
( motor is running during this) i cant go back the the shop cause my car was broken into after he left it unlocked, so im taking the guy to court. any good guesses?
vinceg143
Aug 20, 2008 03:24 PM
do0dfromcali
Feb 16, 2004 10:50 PM
RedRacerCivic
Nov 22, 2002 07:54 PM
