Mini-Me question... D16Y8 or D16Z6 head?
i know im probably gonna get flamed for this but i just wanted to know is there really much of a difference i mean it seems to me they produce about the same power and torque but im still not sure... i guess i shoudl really search more but 30 minutes of reading **** that doesnt help me is pointless and a waste of time so i decided to post.
From: spinning DnB till your head explodes,jersey/philly
well first of all searching is prety easy and it doesnt take 30 mins to figure this out.
try to get a y8 head. flows better than the z6 head stock vs stock, and u dont have to cut ur dizzy out to fit.
From: Fairmont is kinda like hell, the only difference, is Fairmont has a polluted river that runs through, the middle of it.
what bottom are you using ?
ive heard good thing's about d16a6 bottom ins with the y8 heads
just want to know what car you puting this it ?
good luck with it
good luck with it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91siredrex »</TD></TR><TR><TD CLASS="quote">well first of all searching is prety easy and it doesnt take 30 mins to figure this out.
try to get a y8 head. flows better than the z6 head stock vs stock, and u dont have to cut ur dizzy out to fit.</TD></TR></TABLE>
well yes i did search and see i found out that the Z6 flows better (https://honda-tech.com/zerothread?id=1152561 ) and now ur saying the Y8 flows better so im confused...sorry i just got into cars a little while ago and so im still in the process of learning :\ unfortunatly
and yes im running a D16A6 bottom end
Modified by brave at 5:33 PM 2/22/2005
If you don't want to convert to OBD-1, you can use your D16A6 (Pre OBD) distributor to the D16Y8 Head. The D16A6 distributor bolts right in the D16Y8 head. I have heard the D16Y8 flows just a tad bit better then the D16Z6, probably not even noticeable. The D16Y8 created a bit more power over teh D16Z6 because of the cam and the slighly higher compression.
The setup I am running right now is D16A6 block with a D16Z6 Head (converted the car over to OBD-I, using a conversion harness and the correct OBD-1 Distributor)
I suggest you search around. There are plenty of sites out there.
Heres putting a Y8 Head on a A6 Block
-Jon
-Jon
wushubrian
11
Jan 6, 2005 04:34 PM
