Help!!!! Hydro Tranny issue
Old Feb 18, 2005 | 08:37 PM
Klutch-Control's Avatar
Default Help!!!! Hydro Tranny issue
A friend of mine has recently done a cable to hydro conversion on my 88 to 91 ef and i cant seem to get the speedometer or reverse lights to work. I just want to know if there are any solutions for this problem.
The swap was a 95 integra LS swap.
Old Feb 18, 2005 | 08:57 PM
RCautoworks's Avatar
Default Re: Help!!!! Hydro Tranny issue (Klutch-Rox)
Convert the vss to an electrical instead of mechanical one. And rewires the reverse lights, usually 2 wires.
Old Feb 20, 2005 | 07:09 AM
Can I have some more detailed info on how to do this?
Old Feb 20, 2005 | 08:00 AM
TrueNorthStar's Avatar
Default Re: (Klutch-Rox)
What speed sending unit are you using?
You do not need to use a electrical vss unless you have a sir, gsr/itr (94"+) gauge cluster.
If you have your stock gauge cluster you need to use a 90-93 Integra vss.
As far as the reverse lights goes you just need to hook up the reverse switch on the transmisson to your stock reverse switch wires on your engine harness.
davidayala831
10
Dec 4, 2017 06:35 PM
crewcut1983
Nov 14, 2012 06:29 AM
Mugen-RR
Sep 24, 2009 02:22 PM
Nightfox
Nov 20, 2007 06:22 PM
^Sammy]!.
Feb 22, 2003 07:09 PM
