Stripped Flywheel Bolt....
Old Feb 18, 2005 | 06:12 PM
all motor b20b's Avatar
Default Stripped Flywheel Bolt....
What do I do to get it off. I already tried to extract it, but it still wont come out.
Old Feb 18, 2005 | 08:02 PM
beaterdriver's Avatar
http://www.sears.com/sr/javasr...60000
my friend used that to remove a stripped headbolt
Old Feb 18, 2005 | 08:21 PM
Full-Race Henry's Avatar
Default Re: (beaterdriver)
We used that and there wasnt enough flywheel bolt for it to grip. We used the 11 and 12
Old Feb 19, 2005 | 12:47 AM
deSigi's Avatar
Default Re: (Full-Race Henry)
Do you have reverse thread drill bits, those are good for last resort situations. Just drill a hole in the center of the bolt and use the reverse drill bit to take it out. It usually works.
Old Feb 19, 2005 | 06:11 AM
Default Re: Stripped Flywheel Bolt.... (all motor b20b)
all motor your avatar is awesome
who's a$$ is that?
Old Feb 19, 2005 | 12:09 PM
Default Re: Stripped Flywheel Bolt.... (beaterdriver)
Thanks, Some chicks off of a web site.
Old Feb 19, 2005 | 05:19 PM
ENDGAME's Avatar
the very last resort would be to drill the hole and the old bolt out a hair larger than it was and retap the hole and use a slightly larger bolt
Old Feb 19, 2005 | 09:46 PM
dmxsoulja3's Avatar
Default Re: Stripped Flywheel Bolt.... (ENDGAME)
have a mobile welder come over and weld a nut on the end and do it like that.
Old Feb 20, 2005 | 03:02 PM
Default Re: Stripped Flywheel Bolt.... (dmxsoulja3)
What happens if its cross threaded and I tap it. will that throw the balance of the bottom end off.
Old Feb 20, 2005 | 08:36 PM
neogenesis2004's Avatar
if it was me I would drill it out just bigenough that the threads were still in there, and then tap it to the original size. more or less your not taping it but just cleaning out the original. Same thing you do on an engine build to make sure threading is clean to get proper torque specs....minus all the drilling lol.
Old Feb 20, 2005 | 11:43 PM
Mike K's Avatar
drill a hole in the middle of it, and use a good, quality extractor.
Old Feb 22, 2005 | 01:05 AM
SexyHatchie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all motor b20b &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, Some chicks off of a web site.</TD></TR></TABLE>
*rolls eyes* hahaha.
romikbal
Mar 10, 2011 05:33 PM
sawedoffcoupe
Aug 16, 2008 05:12 AM
NSTY Z33
Welding / Fabrication
Mar 19, 2007 05:41 AM
all motor b20b
Feb 19, 2005 12:00 AM
hellas
Jan 21, 2003 12:33 PM
