VAFC Bad???
Old Feb 18, 2005 | 06:01 PM
93gsrcoupe's Avatar
Default VAFC Bad???
Has anyone ever had a VAFC that didn't work? I just installed a used one and the vtec won't engage. I have a chipped p28 which usually set off vtec at 5600, but now nothing happens. The VAFC says that vtec is on, but nothing happens. I had this installed at a shop, and everything works except this. What could be wrong?
Old Feb 26, 2005 | 02:10 PM
Vtec92Civic's Avatar
Default Re: VAFC Bad??? (93gsrcoupe)
could simply be that they hooked it up wrong. I mean its always a possibility. Just don't overlook anything. Check the wiring, check your vtec oil pressure switch, check your ecu just double check it all and make sure that you have the settings correct on your vafc.
Old Feb 26, 2005 | 03:22 PM
zman's Avatar
Default Re: VAFC Bad??? (Vtec92Civic)
check to see in the settings what the V/T CONT says for L->H and H->L. If it says **** then there are no changes made by the vafc.
Or maybe the purple wire or pink wire from the vafc is not connected properly to your cars wiring harness, also check the yellow wire and white wire
1999CivicSi
Sep 24, 2005 12:00 PM
Shakes
Feb 26, 2004 01:39 PM
wgs0023
Feb 26, 2004 03:49 AM
Akkord29
Sep 13, 2003 08:29 PM
VTC_CiViC
Sep 13, 2001 08:38 PM
