B20 head buildup
Am I missing anything?
P8R head
crower cams
crower valve springs and retainers
Buddy club cam gears
Head gasket (cometic)
Is there anything else I need to do... I know I could do valves and get a P&P, but its a lot of extra cash... is there anything else I NEED
anything I should know?
For the head gasket, I'm going to need one that is 84mm, does Cometic sell one in that size?
P8R head
crower cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">New seals! Make sure your valve guides aren't worn</TD></TR></TABLE>
I'll check them both
The block has 100,000 kms on it. The head, I have no idea!
DO an entire rebuild. new bolts(head, rod), bearings, rings, and seals! Take the block and head to a machine shop and have them cleaned and check the flatness of the surfaces! It'll only cost about $50-60!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">DO an entire rebuild. new bolts(head, rod), bearings, rings, and seals! Take the block and head to a machine shop and have them cleaned and check the flatness of the surfaces! It'll only cost about $50-60!</TD></TR></TABLE>
I assume you mean $50 for just the cleaning and checking?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigC-ivic »</TD></TR><TR><TD CLASS="quote">
I assume you mean $50 for just the cleaning and checking?</TD></TR></TABLE>
I paid $50 and got my block and head hot tanked and the resurfaced
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigC-ivic »</TD></TR><TR><TD CLASS="quote">when you said rings?
did you mean piston rings?</TD></TR></TABLE>
yes
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigC-ivic »</TD></TR><TR><TD CLASS="quote">Am I missing anything?
For the head gasket, I'm going to need one that is 84mm, does Cometic sell one in that size?</TD></TR></TABLE>
OEM HG for a CRV will work also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueTeg »</TD></TR><TR><TD CLASS="quote">CRV HG = 84mm bore
I'm familiar w/ the P8R heads. I bought and sold 2 of them.
excellent, thanks!
</TD></TR></TABLE>excellent, thanks!
I would get a set of stainless steal valves also. I dont recommend that you use stock valves with those springs. Ive seen alot of ppl brake stock valves. Stock valves are not meant to have all that spring pressure and will cause valve failure.
You will be fine with stock valves. I've known tons of people (myself included) who have run the crower springs w/out any damage to the oem valves.
jyacoba2009
Nov 23, 2009 08:25 PM
Y2KGreenGSR
Nov 1, 2002 06:03 PM
