mini me swap with hf block
Old Feb 18, 2005 | 02:56 PM
jake1511's Avatar
Default mini me swap with hf block
hey guys, just wondering... can the hf engine handle a mini me swap?
Old Feb 18, 2005 | 03:08 PM
vanos_pusha's Avatar
Default Re: mini me swap with hf block (jake1511)
why?.......................
Old Feb 18, 2005 | 03:10 PM
Dwight Schrute's Avatar
Default Re: mini me swap with hf block (single_cam_ham)
no, the pistons only have 8 valve reliefs.
Old Feb 18, 2005 | 03:12 PM
CRX_Control's Avatar
Default Re: mini me swap with hf block (drewthomas14)
yes the engine can have a mini , just switch out the pistons for 16 valve reliefs.
Old Feb 18, 2005 | 03:14 PM
dr_latino999's Avatar
No it can't unless you switch the pistons out to the appropriate 16 valve pistons from either a D15B2 or D15B7 (there may be others but these are the best for keeping the compression in the right area)
Old Feb 18, 2005 | 03:37 PM
Magick211's Avatar
Default Re: mini me swap with hf block (dr_latino999)
Yes the hf pistons only have 8 valve reliefs, and the logical thing to do would be to swap a6 pistons in... However there has been people who have swapped the head on without changing pistons but im not sure of the outcome
Old Feb 18, 2005 | 04:37 PM
jake1511's Avatar
cool thanks
Old Feb 18, 2005 | 06:10 PM
FalkenSiR's Avatar
Default Re: (jake1511)
What about 88 d15b1 pistons. The 88 std has 9.6 cr instead of 89-91's 9.2. Just wondering...
Old Feb 18, 2005 | 06:17 PM
phatrick2332's Avatar
I have heard that its possible to use the hf block for a mini me. Its been a while but my buddy told me about it when he had an hf. Supposidly they ran better than other mini me becuz of compression. But its just what i heard, and it was prolly 2 years ago.
Old Feb 18, 2005 | 06:35 PM
shocker's Avatar
the cx motor has only 8 valves also,but the pistons have 4 valve reliefs on each....are you sure the bottom end isn't the same except for the head??
Old Feb 19, 2005 | 04:33 AM
Default Re: (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">What about 88 d15b1 pistons. The 88 std has 9.6 cr instead of 89-91's 9.2. Just wondering...</TD></TR></TABLE>
What causes that extra .4 bump in compression? I was under the impression that it shared the same head and pistons with the B2.
SlowMotion
Apr 8, 2004 09:01 PM
Simple SOHC
Nov 4, 2003 12:18 PM
slowpokesi
Jun 2, 2003 02:01 PM
Hondasaurs
Apr 14, 2002 10:36 AM
maximedx
19
Jan 30, 2002 12:08 PM
