making manifold, what size pipe???
Old Feb 18, 2005 | 02:39 PM
GroundZer0 336's Avatar
Default making manifold, what size pipe???
what size tubing should i use for my manifold? i can get 1.37" i.d. and 1.62" id.
ill probably be ordering it from jgs precision. are there any other sites that have stuff for making manifolds???
Old Feb 18, 2005 | 02:57 PM
beepy's Avatar
Default Re: making manifold, what size pipe??? (GroundZer0 336)
What sort of manifold?
Old Feb 18, 2005 | 02:59 PM
Muckman's Avatar
Moderator in Chief
id use whatever size the exhaust ports are.
Old Feb 18, 2005 | 04:11 PM
Default Re: making manifold, what size pipe??? (Muckman)
well its gona be a log style...kinda. its going to be like one i saw on a car on this site. kinda log style. ehh i think ill get 1.62i.d.
Old Feb 18, 2005 | 04:52 PM
beepy's Avatar
If log style than just buy some Tees and Els in Schedule 40 from http://www.mcmaster.com/. What size to get will depend on where you want the turbo to be most efficient. Smaller sizes will spool sooner but won't breath into the higher RPMs as well.
Old Feb 19, 2005 | 12:39 PM
well im boosting my b18a1 and wont really be going above 6500rpm. so smaller would probably be better right just so it spools faster and wont need power at very high rpms since im not going above 6500-7000rpm? o and its a t3 if it matters
Old Feb 19, 2005 | 01:06 PM
01geeser's Avatar
New User
from mcmaster.com. p/n#45605K515 for the 90 degree elbows and p/n#45605K625 for the T's.
Old Feb 19, 2005 | 01:27 PM
onefstek's Avatar
Default Re: making manifold, what size pipe??? (01geeser)
I used the 1.5" sched. 40, 90 deg bends from mcmaster. u might want to go smaller if you are not going to run much boost. don't know what your intentions are.
Old Feb 19, 2005 | 01:56 PM
Default Re: making manifold, what size pipe??? (98ctr)
ok, for now until i get things worked out im going to run 5.6psi, then when all my stuff like fuel and all that good stuff is worked out im going to run 7-9 psi on my t3. wont shift above 7k rpm. yeh so thats what all im gona be makin this for. want it to spool fast but still have good power up top.
Nick_p
Welding / Fabrication
11
Dec 1, 2011 01:11 PM
turbo_d
12
May 1, 2010 02:15 PM
Roky
Jan 11, 2004 02:32 PM
EGJDM
Mar 17, 2003 02:11 PM
Apex i ITR
Feb 7, 2003 07:46 AM
