Sohc Vtec Turbo or B16 100 Shot
Old Feb 18, 2005 | 01:46 PM
The DX Rex's Avatar
Default Sohc Vtec Turbo or B16 100 Shot
basically just vote, confused on which setup i should do. i calculated everything and this is what it will cost ME.
Sohc Vtec Turbo - $3000
forged internals and all the goodies etc...
B16 Direct Port 100 Shot - $3850
all this in a VX and lookin to run 12s
Old Feb 18, 2005 | 02:01 PM
b16boost's Avatar
Default Re: Sohc Vtec Turbo or B16 100 Shot (nyhustla2k)
Sohc turbo you can boost anytime you want and never worry about running out.
Old Feb 18, 2005 | 02:16 PM
MooreBoost's Avatar
Dont build the B16 and just spray a 75 shot to it with a single fogger.
Old Feb 18, 2005 | 02:17 PM
W O T's Avatar
Default Re: Sohc Vtec Turbo or B16 100 Shot (b16boost)
Why the **** you go forged internals for a 100 shot?
Your B16 will take a 100 shot stock and laugh for a long time and spend that money you woulda spent on internals on a nice header, intake mani and maybe some headwork....
I would go turbo d16 but no way in hell would I build a B16 for a 100 shot. Go nothing under 150-200 2 stage if you build your motor for n20
Old Feb 18, 2005 | 03:01 PM
Zakar's Avatar
Bseries all the way
Old Feb 18, 2005 | 03:18 PM
USDM 4G VTEC's Avatar
SOHC VTEC turbo
power on demand
its more fun than N2O
Old Feb 18, 2005 | 04:00 PM
MooreBoost's Avatar
Default Re: (USDM 4G VTEC)
The thing with spraying a 200 shot is that your only going to get in one, maybe two decent runs on a 10lb bottle.
The nice thing about a B16 with a bottle will be that he will have a "sporty" reliable car then something pretty quick on the bottle.
Old Feb 18, 2005 | 04:16 PM
The DX Rex's Avatar
Default Re: (MooreBoost)
this makes it an even harder decision, its going back and forth between sohc turbo and dohc spray. thanks for all the input so far.
Old Feb 18, 2005 | 04:38 PM
D16y8-T's Avatar
Default Re: (nyhustla2k)
SOHC turbo
Old Feb 18, 2005 | 04:58 PM
mrbsponge's Avatar
100 shot, B20 , or b20 vtec
Old Feb 18, 2005 | 05:06 PM
_entropy's Avatar
Default Re: (mrbsponge)
L-O-L
Good luck doing a fully built turbo SOHC for 3 grand that isn't a POS
Old Feb 18, 2005 | 05:49 PM
The DX Rex's Avatar
Default Re: (Napoleon Dynamite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Napoleon Dynamite &raquo;</TD></TR><TR><TD CLASS="quote">L-O-L
Good luck doing a fully built turbo SOHC for 3 grand that isn't a POS </TD></TR></TABLE>
D16z6 block - $50 from junkyward - lucky find
JDM Sohc Vtec ZC head - $100 from a friend
D16z6 tranny - $75 from junkyard - lucky find
Forged JE pistons - $400
Eagle Rods - $300
Rev Hard Manifold - $250
Turbonetics Wastegate - $200
Custom Intercooler Piping, Custom 3in. downpipe, Custom 3 in. exhaust - $400-500, prolly less, my boy owns a mandrel bending machine.
Front Mount - $200
Injectors - $75
FMU - $75
VAFC - $275
Uberdata or Hondata - $200 or dyno tune $150
Greddy RS BOV - $200
those r the prices that im 99% im going to pay for everything if not cheaper. Thats $2850. not including clutch and flywheel which isnt much more for a D series.
when i said fully built im only referin to the bottom end not head, only plannin on runnin like 10 psi
Old Feb 18, 2005 | 05:54 PM
W O T's Avatar
bearings, gaskets, oil pumps, head gaskets, assembly, fluids, headstuds, machine work
It adds the **** up
I built my sohc to the **** including massive headwork and an LSD for under 3k but you seem to just not know what you want
Old Feb 18, 2005 | 06:00 PM
Mr_Bojangles's Avatar
I am running .7 bar (basically 10psi) on my stock bottom end d16z6 right now, with a conservitive tune and I haven't had any problems.
Why build the bottom like that for 10 psi?
The DX Rex's Avatar
Default Re: (W O T)
sure don't
Old Feb 18, 2005 | 06:01 PM
The DX Rex's Avatar
good point
Old Feb 18, 2005 | 06:06 PM
miro_gt's Avatar
Default Re:
I'm about to turbo my D16Z6 with stock internals, and go up to 9-10 psi in the future ...with new turbo components only, for no more than $2500 at all.... and the engine has 102K miles ...
Old Feb 18, 2005 | 06:28 PM
MooreBoost's Avatar
Default Re: (W O T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">bearings, gaskets, oil pumps, head gaskets, assembly, fluids, headstuds, machine work
It adds the **** up
It sure does. That stuff cost me about 250 and I got it for nearly at cost from an HT member that works at Honda. If I hadn't found him it was going to be over 200 for the bearings alone.
And trust me, there is always something else, it never ends.
Old Feb 18, 2005 | 07:46 PM
illusive's Avatar
As others have stated before nitrous is fun yes, but you dont have it all the time....where turbo its there when you want it. I did nitrous a while back been there done that....not as much fun as my turbo setup.
Old Feb 18, 2005 | 07:51 PM
W O T's Avatar
Default Re: (illusive)
Im also an N20 converted to boost junkie
The **** doesnt run out
Old Feb 18, 2005 | 08:39 PM
Civicman86's Avatar
Default Re: (W O T)
boosted single cam. Some really nice numbers going around on the d. Boost can be as realiable as NA just need a good tune and be smart about driving it normal.
Old Feb 18, 2005 | 10:19 PM
mrbsponge's Avatar
why not build the b16 AND TURBO/NITROUS IT..............................like mine is!!!
Old Feb 18, 2005 | 11:38 PM
SOHC_MShue's Avatar
screw nitrous unless drag racing is all you care about. Also a turbo d series running 10psi will not need to be built. You can run 10psi on a stock motor no problem.
eghatchomar
21
Dec 17, 2004 02:14 PM
b16showoff
Jul 11, 2003 10:39 AM
showoffb16
Jun 24, 2003 09:21 PM
1tyme
Oct 26, 2002 10:42 AM
