Proper way to remove lower bolt on rear suspension???
Old Jan 18, 2002 | 09:58 AM
Tommy_Gunns's Avatar
Default Proper way to remove lower bolt on rear suspension???
What is the proper way to remove the lower bolt that connects the strut to the lower control arm on the rear suspension?
I've done a few suspension installs and have broken the head off of that bolt 3 times (EK, Integra RS, CRX). It seems all the rust and grime seizes that bolt.
Old Jan 18, 2002 | 10:02 AM
sgT's Avatar
sgT
Default Re: Proper way to remove lower bolt on rear suspension??? (Tommy_Gunns)
On older cars the bolt siezes to the bushing in the LCA.
In that case you have to cut the bolt, remove the shock, and replace the bushing.
Old Jan 18, 2002 | 10:07 AM
Default Re: Proper way to remove lower bolt on rear suspension??? (sgT)
That's what I have been doing. Dang it, I thought there was a proper way to do it without replacing the bolt and bushing.
Here in Canada (with the extreme weather changes), 2 year old cars have seized bolts. And to top it all off, the local honda dealer does not keep these in stock (idiots!).
Old Jan 18, 2002 | 10:10 AM
sgT's Avatar
sgT
You should take them out while they can be and put some antiseize in there
Old Jan 18, 2002 | 10:14 AM
Mike K's Avatar
gott love FL weather, the fact that it NEVER snows and there is no salt on any of the roads.
Old Jan 18, 2002 | 10:37 AM
Default Re: Proper way to remove lower bolt on rear suspension??? (Mike K)
Sure, rub it in.
-Tommy who hopes to land a job in Florida sometime soon.
Old Jan 18, 2002 | 10:39 AM
ZygSpeed's Avatar
Not only do they not keep them in stock, I actually tried ordering them for my 85 CRX (at least once), and all they can find on the parts diagram (and what they keep sending me) is the bolts that keep the brakes/backing plate onto the control arm! :mad
Mike K -- got a part number for those babies?
Otherwise I'll be shopping at the hardware store for some big metric sized bolts!!
Old Jan 18, 2002 | 10:47 AM
IN VTEC's Avatar
With Remington 12 gauge shotgun at point blank; execution style. No remorse on that Bizatch.
Just kidding. I'm having way too much fun.
Use an impact wrench. But, even with that, the threads (on the shock fork nut) get kinda ruined after so many removals.
Good luck with it.
sgT's Avatar
sgT
Default Re: Proper way to remove lower bolt on rear suspension??? (zygspeed)
whats important about that bolt is that its ribbed. thats supposed to keep
it from seizing to the bushing.
but if you absolutely cant find one, it can be replaced with anything that fits
just use some grease/antiseize.
im sure i have some in my stockpile of bolts
Old Jan 18, 2002 | 12:29 PM
typer_801's Avatar
I liberally applied rusted bolt spray on stuff to whole assembly (both sides) and let it sit for about 15 minutes. Then put ratchet and socket on the nut and used my floor jack to apply increasing pressure on the ratchet. In a matter of no time on both sides the bolts broke free
Old Jan 18, 2002 | 12:33 PM
Willard's Avatar
Two words...
SMOKE WRENCH
Get some poly bushings, 2 extra bolts (I think the ones that mount the arm to the car will work) a few hours under the car.
Will
-who spew a load of curse words while trying to replace shocks on another car
Old Jan 18, 2002 | 12:42 PM
AssPenny's Avatar
Default Re: Proper way to remove lower bolt on rear suspension??? (Willard)
SMOKE WRENCH
hahahaha... thats great... never heard it called that before Smoke Wrenches are your friend. You can also try heading the out side of the LCA aroudn the bolt and the LCA should expand enought to alow you to take the bolt off.
Homotor
Mar 21, 2008 12:47 PM
unhappy_idle
May 16, 2006 09:22 AM
WNT KCH
Oct 13, 2005 10:14 PM
_Shadow_
Aug 28, 2002 04:55 PM
