will this exhaust system fit?
Old Feb 18, 2005 | 10:01 AM
AZNBIGPIMPN505's Avatar
Default will this exhaust system fit?
will a 92-95 civic catback fit my 99 civic coupe?
Old Feb 18, 2005 | 10:02 AM
dantastic's Avatar
Default Re: will this exhaust system fit? (AZNBIGPIMPN505)
if its a 92-95 ex coupe and your car is an EX coupe, it should fit fine. the EX has a different exhaust manifold/cat layout than the DX, so make sure it's off an ex.
Old Feb 18, 2005 | 03:19 PM
sohcturbo16's Avatar
Default Re: will this exhaust system fit? (dantastic)
will the 99 civic si catback fit the 99 civic hx???
Old Feb 18, 2005 | 03:29 PM
TeamNextGenChris's Avatar
Default Re: will this exhaust system fit? (sohcturbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcturbo16 &raquo;</TD></TR><TR><TD CLASS="quote">will the 99 civic si catback fit the 99 civic hx???</TD></TR></TABLE>
don't thread jack!check your post.
Chris
Old Feb 18, 2005 | 03:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">if its a 92-95 ex coupe and your car is an EX coupe, it should fit fine. the EX has a different exhaust manifold/cat layout than the DX, so make sure it's off an ex.</TD></TR></TABLE>
both the DX and EX 92-95 Civics had the cat under the car,so there is no difference as far as that goes-the 92-95 coupe exhaust are all the same.
of course,on the 96+ coupes,only the EX and Si had the undercar cat.the HX and DX had the built in cat on the mani....so it will matter which trim level the 99 civic is.if it's an Si/EX it should work.if it's an HX/DX it will require a test pipe or lengthening of the midpipe.
Chris
Jazlynsciviclx
Mar 14, 2014 09:54 PM
EJ8chu
Feb 17, 2007 10:51 PM
HONDA-2NR
Jan 16, 2004 08:53 PM
pcBaktus
Apr 23, 2003 12:36 PM
PoWeRBaN_PaNdA
Jan 15, 2003 06:43 AM
