are these spark plugs right?
I use BKR7ES-11, but that is on a small turbo / lowboost. I think it depends on boost level / HP for how much colder you should go, but I could be wrong. 1 step colder worked well in my car. Hope I helped
yeah...im going to be running about 8 pounds on the stock motor...with a t28/t3ish size turbo....exact specs unknown...its proprietary or something
the car will be tuned with an apexi power fc and be using 550cc injectors and a 255 lph fuel pump.....should i go colder?
thanks for the input
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin »</TD></TR><TR><TD CLASS="quote">I'd go with BKR7ES. 8 series is pretty cold for a daily driven motor.</TD></TR></TABLE>
And expensive if my memory serves correct...
