b16a and b16a2
Old Feb 18, 2005 | 06:20 AM
civicprojectPR's Avatar
Default b16a and b16a2
hi again i want to know how i know if a engine is b16a or b16a2 becuase for me it look the same i know the b16a has 160 and the a2 has 170 but superficially looks the same !!! well thanks regards
Old Feb 18, 2005 | 06:25 AM
DeKaP's Avatar
Default Re: b16a and b16a2 (civicprojectPR)
im not sure but doesnt it say right there on the block b16a2 and on the first gen it says just b16a i think right? i havent seen my cars block in sooo long i dont even remember,
Old Feb 18, 2005 | 06:38 AM
EP3_05's Avatar
There is a block stamp with the engine code between the block and trans and to the left of the exhast manifold. It is easy to find.
Old Feb 18, 2005 | 08:05 AM
civic277's Avatar
go to hybridhonda.com they have all the info you'll need to know about the first and second gen B16 motors
Old Feb 18, 2005 | 08:11 AM
PHOBIA's Avatar
you will also notice that the a2 has a hydro clutch and the first gen is cable. it will give you the engine codes right on ther block.
Old Feb 18, 2005 | 08:14 AM
Deetz's Avatar
Crazy Honda Guy
All jdm B16A are stamper the same..."B16A" with no extra number beside it. 1st gen and 2gen B16's are most easily identified by the wire harness. A 1st gen has milky white plugs on it and uses 2 O2 sensors, 2nd gen engines has grey plugs and use only one heated o2 sensors further back on the header.
Its that simple.
Old Feb 18, 2005 | 08:18 AM
PHOBIA's Avatar
well that kinda only applies if your buying from a importer like hmoters,because i have 2 b16 blocks and i am going to convert the one in my car know to obd1, should i decide to sell it.that motor know has grey plugs that has one o2 sensor.
Old Feb 18, 2005 | 09:25 AM
turboZChatch's Avatar
Default Re: (PHOBIA)
You can look on the head right above the exhaust manifold for the date it was made that will tell you what it is if it is jdm if it is not a jdm motor then it would say b16a2 if it is an a2
Old Feb 18, 2005 | 09:39 AM
crxtreme89h's Avatar
Default Re: (turboZChatch)
What if it is B16a then followed by a long number starting with a 5?
Old Feb 18, 2005 | 09:44 AM
Deetz's Avatar
Crazy Honda Guy
^^^ Sounds like an obdII usdm B16.
Old Feb 18, 2005 | 09:53 AM
ajcrx's Avatar
A first gen B16A's valve cover has "DOHC" written in a larger font than "VTEC". A second gen B16A's valve cover has "VTEC" written in a larger font than "DOHC".
Old Feb 19, 2005 | 06:27 AM
thanks for the info guys much apriacite
deeb_xiong
May 19, 2014 07:02 AM
T3k C
Dec 4, 2005 05:38 PM
sol2nr
Apr 13, 2004 11:07 PM
B_CRUZ!
Dec 15, 2001 10:08 AM
