Apexi power fc VS Hondata S100
Old Feb 18, 2005 | 01:54 AM
Edward's Avatar
Default Apexi power fc VS Hondata S100
I want to mods toda cam and cam gear, valve spring and port the head. Which cpu can make more power and accurate ( apexi power fc or hondata s100 )??
Does anyone know how much about the hondata s100???
Thanks
Old Feb 18, 2005 | 06:30 AM
B18CXr's Avatar
Default Re: Apexi power fc VS Hondata S100 (Edward)
Power FC
Old Feb 18, 2005 | 06:31 AM
BlueR's Avatar
Default Re: Apexi power fc VS Hondata S100 (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">Power FC </TD></TR></TABLE>
Old Feb 18, 2005 | 06:51 AM
db8sirg's Avatar
jack, is p1 an POWER EXCEL shop yet?
Old Feb 18, 2005 | 07:06 AM
Edward's Avatar
Any Help!!!!!!!
Old Feb 18, 2005 | 07:13 AM
Type-R Yo!'s Avatar
New User
Default Re: Apexi power fc VS Hondata S100 (db8sirg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8sirg &raquo;</TD></TR><TR><TD CLASS="quote">jack, is p1 an POWER EXCEL shop yet?</TD></TR></TABLE>
Apexi will be at the shop on March 1.
Power FC.
Old Feb 18, 2005 | 07:16 AM
db8sirg's Avatar
Default Re: Apexi power fc VS Hondata S100 (Type-R Yo!)
sweet. looks like ill have to start saving my money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-R Yo! &raquo;</TD></TR><TR><TD CLASS="quote">
Power FC. </TD></TR></TABLE>
Old Feb 23, 2005 | 10:59 PM
Who's_Next's Avatar
damn..i was about to get rid of my POWER FC for a hondata unit....
Old Feb 23, 2005 | 11:06 PM
rodrez.'s Avatar
I just sold my Hondata S100 and picked up a Power FC to go with my Toda B's. Power FC is awesome
Old Feb 23, 2005 | 11:34 PM
Yellow3TypeR's Avatar
Default Re: Apexi power fc VS Hondata S100 (rodrez.)
all depends on the tuner. Around here, there aren't many quality Power FC tuners, so check your area first.
Old Feb 23, 2005 | 11:37 PM
98R-641's Avatar
For those who are using power FC, do you remove the 1st O2 sensor?
I am using power FC and got it tuned, however, the tuner told me to keep 1st O2 sensor unattached, however, i find it extremely annoying that whenever the weather is expericing drastic change, i am either running to lean or too rich.
Old Feb 23, 2005 | 11:50 PM
SuperTwinz's Avatar
They just came out with the Power FC Pro in Japan.
Old Feb 24, 2005 | 02:23 PM
B18CXr's Avatar
Everything "should" be final around the first few weeks of March.
Old Feb 24, 2005 | 02:43 PM
Stein's Avatar
Any particular reason why you prefer Power FC Jack?
Old Feb 25, 2005 | 07:15 AM
B18CXr's Avatar
Default Re: Apexi power fc VS Hondata S100 (Stein)
yes, every reason
*once you add up all the "al a carte" chit you need with the hondata unit to equal the FC, your in the same price range
*real time tuning/changes on the fly
*monitor mutiple channels real time via the commander (no laptop needed for this)
*boost control thru the unit (with addition of the apexi solenoid)
the only other option that is "better" from a cost standpoint is Neptune
Old Feb 25, 2005 | 12:59 PM
Spunkster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">Any particular reason why you prefer Power FC Jack?
yes, every reason
If you are comparing the s100 then I'm not sure how you are figuring it costs more...the very most an s100 even with the boost option will cost is $445. This is specifically designed to be less expensive and can be tuned by any Hondata dealer. The s200 is similarly priced but you can add additianl options and you can buy software and hardware to tune yourself.
Also any fully tunable system that has complete control of timing, revlimits, vtec and fuel will be able to make the same amount of power in a GOOD tuner's hands. The differences are in tunability and daily drivability.
Old Feb 25, 2005 | 01:23 PM
B18CXr's Avatar
Default Re: Apexi power fc VS Hondata S100 (Spunkster)
please reread my post from above...
it comes out around $1,055 BTW AND you'll need a laptop if you wish to tune yourself.
Old Feb 25, 2005 | 02:43 PM
esponet's Avatar
sidenote, where can i get a software so i could use my laptop to tune power fc??? software.
Old Feb 25, 2005 | 02:46 PM
Pondus's Avatar
Default Re: (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">sidenote, where can i get a software so i could use my laptop to tune power fc??? software. </TD></TR></TABLE>
Here : http://www.fc-datalogit.co.nz/
Old Feb 25, 2005 | 05:04 PM
chad's Avatar
Moderator
Old Feb 25, 2005 | 10:12 PM
Reid's Avatar
Global Moderator
Default Re: Apexi power fc VS Hondata S100 (chad)
Power FC
Old Feb 25, 2005 | 11:01 PM
SwiftTypeR's Avatar
New User
What about Neptune? Cheaper than Hondata and better.
91 DA Revived
Sep 18, 2010 08:50 AM
SoSoxGino
Nov 7, 2003 01:20 PM
b18turbocivic
May 25, 2002 03:31 AM
R3dL1n3
Apr 23, 2002 09:55 AM
