integra LS.....no gears????
Old Feb 17, 2005 | 11:34 PM
acovertime's Avatar
Default integra LS.....no gears????
i have a 94 integra ls yesterday i was driving down a frontage road i had took off from a stop sign an i took first gear to 7,000 RPM's i put it in 2nd gear heard a strange noise when i let the clutch out and there was nothing my rpms just went up an car was coming to a stop so i dunno what the problem is i dont know if i burned the clutch, broke a flywheel, or fu**ed my tranny if anyone knows what it is help me please......thanks
Old Feb 18, 2005 | 03:13 AM
DC 2's Avatar
Default Re: integra LS.....no gears???? (acovertime)
still have pressure from ur clutch pedal?
check clutch m/c for loss of fluid.
Old Feb 18, 2005 | 08:37 AM
95lstegman's Avatar
Default Re: integra LS.....no gears???? (DC 2)
yeah, we need to know two things: does it feel normal when you put it into gear (does the stick feel normal), and does the clutch pedal have normal feel?
Old Feb 18, 2005 | 11:15 AM
acovertime's Avatar
Default Re: integra LS.....no gears???? (95lstegman)
it has gotg normal feel in the clutch area and pretty much the stick does to it seems like the gears just aint grabbin......also when i pushed the car foward about 8 feet the car locked up.......dont no if this helps at all .........also i forgot there is some strange fluid leaking from underneath my steering wheel under the dash...just found that out
Old Feb 19, 2005 | 12:17 PM
acovertime's Avatar
k here is the deal i started my car for first time today an i put the car in gear 1st 2nd etc in 1st it made a raddeling noise an the higher the gear the worst the noise an raddle put it n 5th an felt like the car was falling apart felt like gearsl just beatin the hell out of everthing an also the mph also went to 80 mph....i dunno whats up
Old Feb 20, 2005 | 03:23 PM
acovertime's Avatar
NEED HELP BADLY......BUMP
Old Feb 20, 2005 | 04:55 PM
boostmywankle's Avatar
hmmm not sure...maybe ur axel popped out????
Old Feb 20, 2005 | 07:08 PM
95lstegman's Avatar
Default Re: integra LS.....no gears???? (96teggyls)
yeah, sounds like broken axle or something. so you're in gear, off the clutch, and on the gas, and you can get the speedo to go up? i'd say axles.
Old Feb 20, 2005 | 07:13 PM
Code Blue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman &raquo;</TD></TR><TR><TD CLASS="quote">yeah, sounds like broken axle or something. so you're in gear, off the clutch, and on the gas, and you can get the speedo to go up? i'd say axles.</TD></TR></TABLE>
im with him
TruenoMike14
Oct 22, 2013 11:36 PM
jrhcivak
17
Apr 11, 2012 03:55 PM
Bizzle5OH3
Transmission & Drivetrain
May 13, 2011 03:05 PM
94teggieGs-r
Aug 18, 2005 10:29 PM
TylerC
Jan 13, 2004 01:25 PM
