Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Stock 14s from a 93 Civic EX
Old Feb 17, 2005 | 10:27 PM
redhondacivic's Avatar
Default Stock 14s from a 93 Civic EX
This is probably an easy question for some you guys to answer but how much does the stock steely from the civic weigh and how wide is it.
I was thinking of going with that for my first season of SoloII. I need a tire thats at least 150 tread wear and up to a 225 width.
Is there a 225 that will work on these steelies. Because I don't think I could have much traction with the 185s that everyone recommends.
I figured that the Honda Gurus would know.
Thanks for any help.
Old Feb 18, 2005 | 01:25 AM
Outrun's Avatar
Default Re: Stock 14s from a 93 Civic EX (redhondacivic)
The wheel weighs about 15lbs or so, but that's on a bathroom scale.
225 might be too wide for that wheel.
Old Feb 18, 2005 | 07:38 AM
Knestis's Avatar
Default Re: Stock 14s from a 93 Civic EX (Outrun)
I run 225 Toyos on 6" wide OE VW wheels so that's not an issue. Whether they fit in the EX fender is another question, and whether they are faster than narrower tires is yet another.
K
Old Feb 18, 2005 | 07:48 AM
Crack Monkey's Avatar
Falken Azenis in 195/60R14 is probably your best bet.
Old Feb 18, 2005 | 08:53 AM
downingracing's Avatar
Default Re: Stock 14s from a 93 Civic EX (Knestis)
I've run the Hoosier 225 on a 5.5" rim... Not recommended, but you can make it work and it will clear the fender - just roll the lip or it will roll it for you!
Old Feb 18, 2005 | 09:02 AM
Default Re: Stock 14s from a 93 Civic EX (downingracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downingracing &raquo;</TD></TR><TR><TD CLASS="quote">I've run the Hoosier 225 on a 5.5" rim... Not recommended, but you can make it work and it will clear the fender - just roll the lip or it will roll it for you!</TD></TR></TABLE>
He said heneeds 150 treadwear, so I'm guessing running STS.
Old Feb 18, 2005 | 09:17 AM
Default Re: Stock 14s from a 93 Civic EX (Crack Monkey)
Does anyone have objection to the Falkens??
Right now I've got studs on the 14s and my "High Performance" tires are 205/40-17 Nankang NS-1 (good for the money) on my "show" wheels but I am definately not gonna run those wheels for competition. Way too heavy.
Old Feb 18, 2005 | 09:28 AM
FormulaIntegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knestis &raquo;</TD></TR><TR><TD CLASS="quote">I run 225 Toyos on 6" wide OE VW wheels so that's not an issue. Whether they fit in the EX fender is another question, and whether they are faster than narrower tires is yet another.
K</TD></TR></TABLE>
I've got 205's on my EX right now, on 6.5" rims. Doesn't appear like there's going to be a rubbing issue with the fender, but if I went up to 225's, I'd probably roll or cut the lip just to not have to worry about it.
Old Feb 18, 2005 | 09:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redhondacivic &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have objection to the Falkens?? </TD></TR></TABLE>
For some reason, peope seem stuck on 225 R-compounds, which is not what you want.
The Falken is widely accepted as the best performance tire for the money. In larger sizes, there are some other options, at twice the price. But in 14", it's your only choice (AFAIK) for a DOT tire that meets the treadwear restriction in STS.
I currently run 15" Azenis on my Miata. No complaints so far. I'll be using them at VIR this weekend.
D-West
Apr 22, 2012 06:28 PM
3joh
Aug 20, 2008 09:27 AM
smores
Feb 23, 2008 11:58 AM
E dwinbon G
Sep 29, 2005 09:06 PM
willyboyK20
Jan 9, 2002 03:41 PM
