More power (NA): cam or ecu tuning
Old Feb 17, 2005 | 09:15 PM
Ragecloak's Avatar
Default More power (NA): cam or ecu tuning
I'm looking at the price of both a stage 2 cam and ostrich/wb setup (tuned with uberdata), and they're roughly the same for what i want. I'm wondering which is going to provide more power, or be more useful. I dont have a vafc, so the ecu tuning would at least allow me to change my vtec point for better acceleration. Car is NA with I/H/E.
Also, on a different note, as far as uberdata goes, am i going to have to have a switch for FTL, or will it be able to automatically turn it on if my car is below a certain rpm?
Old Feb 17, 2005 | 09:18 PM
Luserkid's Avatar
Default Re: More power (NA): cam or ecu tuning (Ragecloak)
Im guessing its your Del Sol right? With a z6? Honestly both things you ask wont do **** without the other. Its pointless to tune a stock motor with only I/H/E and its pointless to run Stage 2 cam without tuning it. The Stage 2 will give you power but not max power, you get it? They both need each other in a sense.
FTL? Do you mean 2 step launch control? If so thats activated by a button.
Old Feb 17, 2005 | 09:25 PM
Ragecloak's Avatar
Default Re: More power (Luserkid)
Yea, z6 sol.
Hmm, someone had mentioned it's always good to tune your car...and i know i read about cams adding like 20+ hp. Plus, like i mentioned, earlier vtec activation.
And yea, two step launch...i know they had it so that it was activated by the ac switch, but i think i remember somewhere that they made it so that it could be used any time your car was below a speed that you set. I dont know why you would want to turn it off...i suppose if you havent tuned your car since you put in a mod that you would want to rev higher with... *shrug*
Old Feb 17, 2005 | 10:17 PM
Luserkid's Avatar
Default Re: More power (Ragecloak)
I/H/E isnt something worth tuning. Max youll get is probably 5+ whp. with a stock motor. Now put the cam in and tune it you could get 20 whp (all depending on how its tuned and who tunes it of course).
But then again dont expect to much off of a mostly stock motor, after all its stock.
Usually you want a later VTEC crossover. You want a VTEC crossover where torque and hp cross. Thats usually the best spot.
I think the way you think of 2 step could only be done with a full stand alone, like AEM EMS and such. But dont quote me on that, from what i remember Uberdata/Hondata both use switches.
Old Feb 17, 2005 | 10:27 PM
JDMlyfestyle's Avatar
horsepower and torqe always cross at 5200 RPM's.. from my experience that always seems to be where they meet..
but seriously you cannot get a cam and just pray that itll work. you gotta tune it to get the best results.
Getting a cam and not tuning it is like getting a turbo kit without a blow off valve. its needed.
Old Feb 18, 2005 | 12:57 AM
teknoracing's Avatar
Default Re: (JDMlyfestyle)
Get the cam first then the ECU. The cam should help out, look to see a slight increase in power but not its full potential. ECU Tuning should definitely unlock the potential of your mods, assuming whoever is your tuner knows what hes doing.
Old Feb 18, 2005 | 01:07 AM
Tad's Avatar
Tad
Default Re: (teknoracing)
get a regrind,
like a deltacam or something,
they're so cheap, you could afford both the cam and the tuning!
that would be the best for sure.
thing is, they go hand in hand.
the more mods you have, the better the cam will work for you.
and the more mods you have, the more you will receive from tuning!
Old Feb 18, 2005 | 02:18 AM
RStoR's Avatar
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">get a regrind,
they're so cheap, you could afford both the cam and the tuning!</TD></TR></TABLE>
delta doesn't make vtec cams
Old Feb 18, 2005 | 07:06 AM
flood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Getting a cam and not tuning it is like getting a turbo kit without a blow off valve. its needed.</TD></TR></TABLE>
WTF? You don't NEED a BOV with a turbo.
If that were the case every OEM turbo application would have one. I can't think of a single Volvo with a BOV. LOL
Modified by flood at 8:25 AM 2/18/2005
Old Feb 18, 2005 | 07:08 AM
OEM turbos use a bypass valve. but for us honda's we need a BOV. cause that excess pressure can do some damage to the throttle plate.
Old Feb 18, 2005 | 08:19 AM
Ragecloak's Avatar
I've heard you dont need a BOV until you get like 17 or 20+ psi
Not to many hondas running that i bet
lol...participating in thread jacking my own thread
Old Feb 18, 2005 | 08:42 AM
Luserkid's Avatar
Default Re: (Ragecloak)
I think what he ment to say was WG. You cant run a turbo without a WG.
Old Feb 18, 2005 | 08:46 AM
well i know for damn sure i wouldnt run a turbo without a BOV either.
Old Feb 18, 2005 | 08:50 AM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">well i know for damn sure i wouldnt run a turbo without a BOV either.</TD></TR></TABLE>
I would if I owned an automatic.
nyghtryder
Honda Civic (2001 - 2005)
Oct 27, 2007 12:28 PM
thehatchninja
Sep 3, 2006 01:48 PM
91 POS
29
Oct 13, 2003 02:16 PM
el arbi
Jan 25, 2003 03:30 PM
