(pics) Turbo kit that we're Fabbing
Old Feb 17, 2005 | 07:14 PM
fullblown's Avatar
Default (pics) Turbo kit that we're Fabbing
Thats the car its going on.
Modified by fullblown at 8:35 PM 2/18/2005
Old Feb 17, 2005 | 07:16 PM
fastcivicboy's Avatar
is that a ssac intercooler? sure looks like it. Maybe im mistaken and it's a precision, correct me if im wrong. -Nick
Old Feb 17, 2005 | 07:23 PM
fullblown's Avatar
haha no way will we ever touch ssac. Its a Apexi Gtr core. And the mani is not a ssac either.
Old Feb 17, 2005 | 07:41 PM
TeamNextGenChris's Avatar
Default Re: (pics) Turbo kit that we're Fabbing (fullblown)
is that pipe on the intake mani just laying there,or is that some new crazy setup we've never seen before?
anyway,where the pics of the fab work?all i see fabbed is one charge pipe.
Chris
Old Feb 17, 2005 | 08:31 PM
fullblown's Avatar
Default Re: (pics) Turbo kit that we're Fabbing (TeamNextGenChris)
hahah yea it's just laying there bro. these were the only pictures we had so we just threw them on here. we'll get some better pics for ya asap but yea here's some pictures of our work! more pics coming soon!!!
Old Feb 18, 2005 | 07:34 AM
Ekasey's Avatar
dood are they putting honda motors ir skylines teeheehee
looks good
Old Feb 18, 2005 | 10:59 AM
nerdsports's Avatar
Default Re: (pics) Turbo kit that we're Fabbing (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">dood are they putting honda motors ir skylines teeheehee
looks good</TD></TR></TABLE>
yea. i was a bit confused...
til i saw the yellow thing on the lift.
specs on the motor... turbo setup?
Old Feb 18, 2005 | 11:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fullblown &raquo;</TD></TR><TR><TD CLASS="quote">hahah yea it's just laying there bro. these were the only pictures we had so we just threw them on here. we'll get some better pics for ya asap but yea here's some pictures of our work! more pics coming soon!!! </TD></TR></TABLE>
ohhh,you're making the the mani too?sorry-i thought you were using a mani you purchased,and the only thing you had actually fabbed was the one charge pipe.
looks good.
Chris
Old Feb 18, 2005 | 05:17 PM
G2turbo_terror's Avatar
What shop is that?
Old Feb 18, 2005 | 06:13 PM
SL0WEGG's Avatar
Default Re: (G2turbo_terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2turbo_terror &raquo;</TD></TR><TR><TD CLASS="quote">What shop is that?</TD></TR></TABLE>
id also like to know. haha im somewhat new to MN and noticed your from minneapolis! very nice welds
Old Feb 18, 2005 | 07:26 PM
fullblown's Avatar
more pics up
Modified by fullblown at 8:36 PM 2/18/2005
Old Feb 18, 2005 | 07:32 PM
fullblown's Avatar
eLusive ek4... thanks for the compliments
nerdsports.... Right now, Its a stock b20 ITR head
and tranny with a our own custom turbo kit, built block
coming soon....
G2turbo_terror & boostedej1........ Thanks, were right in bloomington. 80th and
Nicollet. Full Blown Motorsports
8041 Nicollet ave s
Bloomington MN
952-830-1399
come check us out!!
Old Feb 18, 2005 | 08:10 PM
TRAY's Avatar
looks great but thats the most hideous looking civic i think ive seen
Old Feb 18, 2005 | 08:59 PM
fullblown's Avatar
Default Re: (pics) Turbo kit that we're Fabbing (TrayDay2K1)
We all have our own taste
Old Feb 20, 2005 | 01:01 PM
Bailhatch's Avatar
how's that oil return line goona work out? seems looooow
Old Feb 20, 2005 | 01:39 PM
Engloid's Avatar
OG Fabricator
Default Re: (pics) Turbo kit that we're Fabbing (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">how's that oil return line goona work out? seems looooow</TD></TR></TABLE>
It's just a drain. It will work even if you put it in at the very bottom of the pan.
Old Feb 20, 2005 | 06:16 PM
HR-1320's Avatar
Default Re: (pics) Turbo kit that we're Fabbing (Engloid)
I think hes talking about the turbo hanging to low to have a good gravity drain towards the oil pan . And no you cannot put the drain in the bottom of the pan. It will back up and the turbo will smoke cause its cooking the oil thats not good.
Old Feb 20, 2005 | 06:52 PM
fullblown's Avatar
Default Re: (pics) Turbo kit that we're Fabbing (2.0Coupe)
It will work fine, pics look low but when youre under the car , u can see that itll work.
Old Feb 20, 2005 | 07:32 PM
Engloid's Avatar
OG Fabricator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.0Coupe &raquo;</TD></TR><TR><TD CLASS="quote">And no you cannot put the drain in the bottom of the pan. It will back up and the turbo will smoke cause its cooking the oil thats not good. </TD></TR></TABLE>
that's not true. It's a myth, just like the "need" for backpressure.
Does your toilet back up due to the design? No.
You can put a tube in at the bottom of the pan, and the oil level in the tube will be the same elevation as the oil in the pan. It's simple physics. The tube will not fill up because it's put at the bottom of the pan.
Just like in your toilet...the water level in the trap will be the same as in your bowl...unless the trap stops up on the other side. Also, consider the trap under your sink. Doesn't the water level stay the same on each side of it?
He just needs to make sure that the turbo is above the oil level in the pan. The amount is irrelevant, as gravity has the same force at one foot as it does at two.
Old Feb 20, 2005 | 08:01 PM
Electron_LS-Vtec's Avatar
what size is that turbo...the hot side is very small compaired to the cold side... what kind of boost are you looking to make?
thanks
Old Feb 20, 2005 | 08:06 PM
philipwight's Avatar
Default Re: (pics) Turbo kit that we're Fabbing (Electron_LS-Vtec)
engloid is correct about the oil return. Stock VWs have the oil return line at the very bottom of the pan with no problems at all.
Old Feb 20, 2005 | 08:20 PM
Engloid's Avatar
OG Fabricator
Default Re: (pics) Turbo kit that we're Fabbing (philipwight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philipwight &raquo;</TD></TR><TR><TD CLASS="quote">engloid is correct about the oil return. Stock VWs have the oil return line at the very bottom of the pan with no problems at all.</TD></TR></TABLE>
Which ones? I'll have to remember this.
Old Feb 21, 2005 | 05:30 AM
donkiman's Avatar
ahhh thick intercooler piping and a bling *** intercooler. bad ***
Old Feb 21, 2005 | 07:29 AM
Default Re: (pics) Turbo kit that we're Fabbing (donkiman)
any of the 1.8t vws have the oil return line at the bottom of the pan. some of the newer 1.8ts 2004 and up have an upper and lower pan so the oil return in half way up due to the lower pan.
Old Feb 21, 2005 | 01:25 PM
DaveF's Avatar
thats a sweet *** manifold
