Will This Cluster Work?
I got a Guage Cluster for an EF Civic. I have a 91 Civic DX Hatch back. I think i got am 89 CRX cluster with tach. Will this be compatible with my Civic?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superhatchbackbros »</TD></TR><TR><TD CLASS="quote">yes
it will plug right in - only diff will be the milage may have to match it up....</TD></TR></TABLE> no , it wont plug right up because the 88-89 differ from the 90-91 clutser.The back plugs wont match unless you rewire them which is a hassle so just get the one your car is compatable with without rewiring.
itll work, jsut have to redo pins to match the cluster... pinout diagrams can be found here...
http://www.ef-honda.com/main/viewtopic.php?t=1400
you would also need an 88-89 cluster cover
Modified by 90civichbsi at 9:10 AM 2/18/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs »</TD></TR><TR><TD CLASS="quote">no it wont fit cuz of the plug.. but you can modify your plug... by buying a 88-89 plug...
or you can sell that and just buy a 90-91.... </TD></TR></TABLE>
i dunno if i jsut have 2 clusters that are different from the one your thinkin of, but i have a 90 si cluster and a 88-89 zc cluster sitting next to me and they both use the same plugs. just with different pinouts
Too much misinformation going around. Holy shiite!
88-89 and 90-91 are different.
Why?
Because they are wired differently.
Do they have the same plugs?
Yes.
Will the tach work once you have it wired correctly?
Yes. Pop the tach cable VSS? onto the cluster.
Is it hard to re-pin the factory wiring harnesses that plug in the cluster?
No, just follow the diagrams for the 88-89.
HF and SI should be the same.
Why?
Yes.
JackAcc
Aug 15, 2003 05:16 PM
