Euro R H22 swap... Just raced a fully built GSR hatch
Old Feb 17, 2005 | 04:38 PM
mdj_ge's Avatar
Default Euro R H22 swap... Just raced a fully built GSR hatch
I have a 95 hatch w/ The Ultimate H22 Euro R swap... i recently took out a fully built b16 hatch and a stock EVO 8.... but last night, i lost to a fully built gsr swap... MY question is, what can i do to make my more power out of my motor... it already has the high compression, type s cams and EURO R manifold... HELP
my Spec's right now: Stock 2001 Euro R... w/ stock headers, cheap short ram intake, custom 2.5 exhaust w/ no cat and using a p28 s200 hondata....it's also sitting on stock civic suspension w/si rims on shitty tires...
BTW... w/p28 chip ecu : i ran 14.6 @ 96 and now with hondata - I haven't got the chance to run it yet...
EDIT : UPDATE on the race... The secret finally came out, the guy was shooting NOS!!!! All his friends and even himself said that he would of lost if he went all motor... HELLA Yeah... H22 all the way...
Modified by yangja at 11:42 PM 3/15/2005
Old Feb 17, 2005 | 05:31 PM
zumH2B's Avatar
Default Re: Euro R H22 swap... Just raced a fully built GSR hatch (yangja)
how far did you lose by and was he a 2.0L built and how was traction? maybe you should get a better header, upgrade your suspension and get the car dyno tuned...good luck
Old Feb 17, 2005 | 05:41 PM
mdj_ge's Avatar
Default Re: Euro R H22 swap... Just raced a fully built GSR hatch (zumb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zumb18 &raquo;</TD></TR><TR><TD CLASS="quote">how far did you lose by and was he a 2.0L built and how was traction? maybe you should get a better header, upgrade your suspension and get the car dyno tuned...good luck </TD></TR></TABLE>
i don't know what his setup was, but it was quick... i was only told that it was fully built... w/ street slicks...
edit : he took me about 3-4 cars....
Old Feb 17, 2005 | 05:48 PM
null.'s Avatar
- regrinded cams from rocket motorsport
- dtr custom header
- blacktraxx intake manifold
you'll be well in the 12s
Old Feb 17, 2005 | 05:50 PM
crxhybrid85's Avatar
Default Re: Euro R H22 swap... Just raced a fully built GSR hatch (eg6junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6junkie &raquo;</TD></TR><TR><TD CLASS="quote">- regrinded cams from rocket motorsport
- dtr custom header
you'll be well in the 12s</TD></TR></TABLE>
12's??
Old Feb 17, 2005 | 06:03 PM
null.'s Avatar
Default Re: Euro R H22 swap... Just raced a fully built GSR hatch (crxhybrid85)
yes 12s (with slicks of course)
Old Feb 17, 2005 | 06:26 PM
s2kkk's Avatar
Only 14.6? Damn man, my times with my B16 in a 92 VX hatch are consistant 14.1's @ 99MPH.
Best time was 13.9 @ 102MPH with 1.9 60 foot on street tires.
How is your traction? You should probably invest in some traction bars with that heavy motor. Keep those wheels on the ground more. Do you have alot of wheel hop?
Old Feb 17, 2005 | 07:04 PM
mdj_ge's Avatar
Default Re: (spoon.eg)
The 14.6 run was with the p28 chipped, untuned, and sitting on some shitty *** tires, plus my car was not even drop... yes, it was really hard to catch tractions, my first run was 16.1 @ 101 mph...(lol) i was only lauching at 2000 rpm... anything higher, i'll be doing burnouts.... it was pretty dissapponted though, since B series swap does the same times... the motor does runs much better when the hondata setup...i haven't timed it yet but possibly in the 13's since i took an EVO8.... the fully built GSR swap that i ran, he told me he was doing 12's ... my motor is just stock as of right now... i just needed some sugestions to make it faster, that's all...
Old Feb 17, 2005 | 07:12 PM
C M S's Avatar
Default Re: (yangja)
Turbo
How bout a Hytech header, or AN-R. Any really good high dollar header...
Old Feb 17, 2005 | 07:22 PM
MadnessRacing's Avatar
Default Re: (1SICJDM)
try to run him again slicked down im pretty sure youll take him..
Old Feb 17, 2005 | 07:37 PM
fsp31's Avatar
Default Re: (MadnessRacing)
You have enough motor there to run deep into the 13's. I'd look elsewhere to solve your problems.
For instance, do something with that suspension! Simply changing the settings on a set of adjustable struts can net 2 or 3 tenths. That's more than a few car lengths right there. If you don't have some serious spring rates (and shocks) out back, then your weight is just transferring rearward, making traction a worse nightmare than it already is on a FWD.
Old Feb 17, 2005 | 07:50 PM
mdj_ge's Avatar
yeah, i'll try the slicks and the most important, dropping it... thanks all... i was also thinking about getting an ITB, SMSP headers and the whole JUN head unit....
Old Feb 17, 2005 | 08:27 PM
2.2L EH2's Avatar
get a smsp header, omni power suspension and slicks.
Old Feb 17, 2005 | 08:31 PM
HoOridin's Avatar
i see that ur from sac.. what part of town u from and give me a lil description of the hatch u lost too...
Old Feb 17, 2005 | 08:39 PM
JDMlyfestyle's Avatar
AN-R header is what you need. You should be cutting way better times than that tho.
13.58@99.9 MPH
on Falken Azenis
2.2 60'
B16a2 stock block
stock ITR head
ITR tranny 4.7 FD
Fidanza Flywheel
South Bend Clutch
Inake
AN-R header merge
RSR GTII exhaust
VAFCII untuned
Mugen P28
Old Feb 17, 2005 | 08:44 PM
. o 69 o .'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6junkie &raquo;</TD></TR><TR><TD CLASS="quote">- blacktraxx intake manifold
never heard of this before, please elaborate
Old Feb 17, 2005 | 10:14 PM
dude_123's Avatar
hey yangja was that a red hatch that u raced? and was he in a team?
Old Feb 18, 2005 | 03:12 AM
Honda_Tengoku's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yangja &raquo;</TD></TR><TR><TD CLASS="quote">I have a 95 hatch w/ The Ultimate H22 Euro R swap... i recently took out a fully built b16 hatch and a stock EVO 8.... but last night, i lost to a fully built gsr swap... MY question is, what can i do to make my more power out of my motor... it already has the high compression, type s cams and EURO R manifold... HELP
BTW... w/p28 chip ecu : i ran 14.6 @ 96 and now with hondata - I haven't got the chance to run it yet... </TD></TR></TABLE>
14.6?? at 96 MPH with the Accord R 220 HP? Kinda slow isnt it? My stock H22A ran 99 MPH traps with 14.1 ET, 2.20 60 foot (with AFRs down in the 11's come to find out). I thought my times the first time I ran it were crap to be honest.
edit : he took me about 3-4 cars.... </TD></TR></TABLE>
street slicks meaning drag radials I take it? 3-4 car lengths doesnt sound too quick to me. No offense but a built GSR hatch will annilate u by a hell of alot more than 3-4 car lengths.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM &raquo;</TD></TR><TR><TD CLASS="quote">Turbo
How bout a Hytech header, or AN-R. Any really good high dollar header...</TD></TR></TABLE>
or SMSP.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">AN-R header is what you need. You should be cutting way better times than that tho.
13.58@99.9 MPH
on Falken Azenis
2.2 60'
B16a2 stock block
stock ITR head
ITR tranny 4.7 FD
Fidanza Flywheel
South Bend Clutch
Inake
AN-R header merge
RSR GTII exhaust
VAFCII untuned
Mugen P28</TD></TR></TABLE>
nice.
Old Feb 18, 2005 | 03:19 AM
NA425DragSter's Avatar
* B A N N E D *
wat color hatch u run
Old Feb 18, 2005 | 06:19 AM
fsp31's Avatar
Default Re: Euro R H22 swap... Just raced a fully built GSR hatch (Honda_Tengoku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Tengoku &raquo;</TD></TR><TR><TD CLASS="quote">
A friend with a mildly built GSR (ported head, CTR cams, SK2 intake mani, thin HG, hondata, and a no-name header) in a 5G hatch that still retains some interior runs very consistent 12.60's on slicks. But then again, he put his money into the *suspension*... see a pattern? His car seriously hooks up even though he launches at nearly 9k rpm's, with 60 ft's in the 1.7 range. Not taking anything away from him though. The guy can drive.
Old Feb 23, 2005 | 02:34 AM
BaNAnABoAt689's Avatar
B A N N E D
From: los angeles, Eagle Rock, CA, united states of america
umm try to get some headers.. makes a read differnce when i put on mines.
im in the high 12s with my JDM h22. PM me ill show you the list of mods i have even though they pretty basic.
Old Feb 23, 2005 | 03:19 AM
Default Re: (NA916DragSter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA916DragSter &raquo;</TD></TR><TR><TD CLASS="quote">wat color hatch u run</TD></TR></TABLE>
my hatch is red.
can view it here...
http://www.tengoku-racing.com/...b.htm
Old Feb 23, 2005 | 04:05 AM
lakerschamp2000's Avatar
you need nothing but learn how to drive. with that Euro R h22, you should be able to hit low 13s all day long.
Old Feb 23, 2005 | 05:08 AM
AirMax95's Avatar
Default Re: Euro R H22 swap... Just raced a fully built GSR hatch (lakerschamp2000)
yeah, thats what i was getting out of that, 14.xx should not be what that car runs
Old Feb 23, 2005 | 04:51 PM
mdj_ge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lakerschamp2000 &raquo;</TD></TR><TR><TD CLASS="quote">
you need nothing but learn how to drive. with that Euro R h22, you should be able to hit low 13s all day long. </TD></TR></TABLE>
i think i'm a good enough driver... it's just the tires that i'm using... anything higher than 2000 rpm i'll do a burn out show...
