How to remove i-vtec stickers from side of car?
mine peeled off pretty good, get this stuff called "Goo Gone" it works really well to get the adhesive off your car with out scratching the paint. that stuff also works with debadging "civic" or "si" ect...
with the sticker ive herd that goo gone and dental floss works too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EtherGhost »</TD></TR><TR><TD CLASS="quote">Hairdryer</TD></TR></TABLE>
best way to do it... the only real pain is the adhesive... i already took off the front grille SI emblem and civic on hatch.... today i took of the rear SI with dental floss and the honda on the hatch too (installing jdm emblem).... it takes quite a while for the adhesive if you don't have wd40 or goo gone.... but it looks clean...
well i took the rear emblems off with floss, googone, and wax, but the stickers on the side seem much harder, ill try during the day when its hot and ill also try using a hairdryer, thanks guys
the hair dryer is what i used, but too much heat can hinder your efforts. hotter is not better. use a little bit of heat move and peal i went from right to left. a little heat will help you peel more of the decal and keep it all intact. too much heat will make the decal brittle and rip easily.
goo gone is ok, but goof off is way better. dampen a cloth with the adhesive remover, and hold the cloth on the adhesive residue for a minute or so, it should be easy to wipe off.
gutted-dx
Oct 1, 2005 01:44 PM
hondamonkey
26
May 16, 2005 02:55 PM
giff74
Dec 12, 2004 05:33 PM
