IAC valve?
Ok ok, getting back to IAC, I'm confused! Two coolant lines on the back of the manifold? I'm not really sure where this is that you are talking about. Can anyone explain a little better?
Id like to see an acurate description of vtec in someones own words
First, let's explain what VTEC does. VTEC (Variable valve Timing and lift Electronic Control) is a way for Honda motors to optimize power and keep fuel efficiency. The way it does this is by having two different cam lobe profiles to open the valves.
How does it do it? Well, it is relativly simple. Like stated before, a Honda Camshaft has two different sets of lobes. Each set of valves is actually operated by three different cam lobes. The smaller of the two lobes, which are palced on the outside of the larger one, operate the valves under normal driving conditions, and at lower RPMs. The cam lobe rides on what is called a rocker. The rocker then transfers its movement to the valve. the larger cam operates what is known as a follower. The follower does not touch any valves. It simply follows the higher cam lobe, which some refer to as the VTEC lobe or profile, until it is needed. Once the engine reaches a certain RPM the follower is brought into play. Oil pressure sends a locking pin through the follower and both rockers essentially locking them together. This allows the rockers to move with the follower which is riding on the higher cam profile. This in turn opens the valves more, for a longer duration, and at a slightly different time. This allows for more air and fuel to enter the combustion chamber for added power.
I hpe that works. Pardon any spelling, grammar, or puncuation errors. i was in a hurry.
look on the back of the manifold which is facing the firewall, the tw coolant lines going vertically into the sensor is the IAC valve
bigsnorlax
Jun 12, 2009 05:06 PM
Mr2KiEu
Apr 5, 2005 11:56 PM
thats why my intake manifold is nice and cool to the touch
