Running 32mm offset on 99 Civic hatch
Old Feb 17, 2005 | 01:24 PM
hc99si1's Avatar
Default Running 32mm offset on 99 Civic hatch
Does anyone have experience of running a substantially lower offset? I've calculated that they will sit 13mm further out.
My car is lowered 2.5 all round. Thanks in advance. If anyone has pics that would be most useful.
Old Feb 17, 2005 | 02:45 PM
boro's Avatar
Default Re: Running 32mm offset on 99 Civic hatch (hc99si1)
a lower offset has a significant effect on scrub radius, load on your wheel bearings/ball joints, yadda yadda.
mind you, track width is increased, roll center improved.. etc.
depending on how much of an increase over stock (I cant remember) it shouldnt produce THAT negative of an effect. make sure everything clears!
Old Feb 17, 2005 | 07:43 PM
bryant's Avatar
You will be fine for clearance. A friend ran a set of 15x7 +32's on his EH and never had any problems with rubbing. Mind you he has 195/50's on. 205's would prolbey be another story and you might encouner some rub.
Old Feb 17, 2005 | 08:09 PM
Moogen Powah's Avatar
Default Re: Running 32mm offset on 99 Civic hatch (bryant)
Currently on 15X7's w/ a +31 offset on my DA. With 195/55 tires, I have not rubbed at all. Keep in mind also, that if you do rub, you could always roll your fenders.
Old Feb 17, 2005 | 09:38 PM
Dorby's Avatar
Default Re: Running 32mm offset on 99 Civic hatch (Moogen Powah)
please post pics of 32 or similar offsets
Old Feb 17, 2005 | 11:20 PM
hc99si1's Avatar
Thanks for the feedback guys, I'm looking forward to picking up my Enkei Racing S rims tommorrow.
I'll get pics up once they're on.
Old Feb 18, 2005 | 06:57 PM
knucklesdragon's Avatar
I would love to see some pics
Old Feb 18, 2005 | 07:43 PM
XrcR6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hc99si1 &raquo;</TD></TR><TR><TD CLASS="quote"> I've calculated that they will sit 13mm further out.</TD></TR></TABLE>
You're correct, assuming what you have now is +45mm offset wheel (like what comes on a lot of Civics) *and* that wheel is the same width as what you are going too. I saw in another of your threads you mentioned the Enkei is a 15x6.5 +32... Do you already have 6.5" wide rims now? If not and its something narrower, you need to halve the difference in the two widths and add that to the offset difference. Just fyi, cause it might be further out than you expected.
Old Feb 18, 2005 | 07:55 PM
slammed_93_hatch's Avatar
Default Re: Running 32mm offset on 99 Civic hatch (Dorby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dorby &raquo;</TD></TR><TR><TD CLASS="quote">please post pics of 32 or similar offsets</TD></TR></TABLE>
195-55-15
Modified by slammed_93_hatch at 1:10 AM 2/22/2005
Old Feb 18, 2005 | 11:51 PM
Dorby's Avatar
Default Re: Running 32mm offset on 99 Civic hatch (slammed_93_hatch)
thanks...anyone with a offset chart????thanks
Old Feb 19, 2005 | 12:57 AM
hc99si1's Avatar
Default Re: Running 32mm offset on 99 Civic hatch (XrcR6)
XRCR6 - you're right, I am running 6.5 now with a 45mm offset.
Try this site if you want to calculate your clearance:
http://toy4two.home.mindspring.com/offset.html
Old Feb 19, 2005 | 11:56 AM
Dorby's Avatar
good post....
Old Feb 19, 2005 | 12:54 PM
heel_touge's Avatar
are most of our OEM steelies 45mm offset?
LEV
Jan 9, 2008 08:58 PM
97hickbatch
Jan 17, 2005 06:25 PM
Die-Laughing
Aug 24, 2004 12:44 PM
.Ryan
Feb 7, 2003 05:46 PM
padraf
Feb 8, 2002 05:17 PM
