Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Actual Width of Kumho Ecsta MX?
Old Feb 17, 2005 | 12:12 PM
NoClassic's Avatar
Default Actual Width of Kumho Ecsta MX?
I am about to buy another set of tires for my SE-R, but wanted to be clear about a few things before I place my order.
Right now I have a set of 205-50-15 kumho ecsta supra 712's on the car. With these tires there is less than a 1/2 inch of clearance between the side wall and rear strut tube. I know that many of the "max performace" tires tend to be a bit wider than most others rated at the same width. For Example https://honda-tech.com/zerothread?id=163023 . I really can not afford to buy extended studs and spacers so i need to know if you guys think ill have rubbing problems with the MX's in the same size as the 712's(205-50-15)?
I know you guys really only care about threads with pics, so here is a usless one just to attract some attention
Old Feb 17, 2005 | 01:54 PM
Boilermaker1's Avatar
Mine measured out to 214mm on a 6.5" rim.
Old Feb 17, 2005 | 02:29 PM
NoClassic's Avatar
Default Re: (Boilermaker1)
Did the sidewall bow out any further than the 214mm measurement when mounted on the 6.5" rim?
EDIT: What i am asking is if you would consider your measurement one of tread width or section width. I thought that may clear things up a bit.
Modified by ITR#1437 at 3:47 PM 2/17/2005
Old Feb 17, 2005 | 02:32 PM
RineRacing's Avatar
Default Re: (ITR#1437)
According to the data at tirerack.com the MX is supposed to be .1" wider than the same size 712. I don't know how well this translates to reality but I would guess it to be reliable.
Old Feb 17, 2005 | 02:36 PM
NoClassic's Avatar
Default Re: (RineRacing)
I had read that as well, but was not sure how accurate their measurements would be. I am going to measure my 712's when I get home just to make sure. Thanks for the help guys. Hopefully the SE-R will be a bit more sticky with the new rubber.
Old Feb 17, 2005 | 03:30 PM
Bbasso's Avatar
Default Re: Actual Width of Kumho Ecsta MX? (ITR#1437)
I have MXs on 15x7 rims take a look I tried my best to get a pic of the width... Its 8 5/8 wide.
Take a look:
Old Feb 17, 2005 | 03:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#1437 &raquo;</TD></TR><TR><TD CLASS="quote">Did the sidewall bow out any further than the 214mm measurement when mounted on the 6.5" rim?
Modified by ITR#1437 at 3:47 PM 2/17/2005</TD></TR></TABLE>
They're fairly straight on a 6.5 there's a little hangout, but the sidewall is fairly square to the tire, no noticable balloon effect.....
8 5/8" comes out to 219mm, so the extra 1/2" of rim only added about .2" to the overall width of the treadblock. Somewhere in there lies the true number.
Old Feb 17, 2005 | 04:13 PM
NoClassic's Avatar
Old Feb 18, 2005 | 05:28 AM
aklucsarits's Avatar
New User
I've got a 1992 Sentra SE-R too. I have 15x7" +35mm ATS Comp Lites with the 205/50/15 Azenis, which are slightly wider than the 205 width MXs . There is no rubbing at all on my SE-R on the inside.
Andrew
Old Feb 18, 2005 | 12:07 PM
NoClassic's Avatar
My wheels have a +40mm offset so im working with a little bit less room than you. By the way I love the look of the ATS wheels on the classics, good choice.
Old Feb 18, 2005 | 12:27 PM
maxQ's Avatar
My SE-R has the same wheels as the "other Andrew".. with Kumho MXs.
Lowered 1.5", I had to keep the rear negative camber less than -0.7° in order to clear my 8611s. FWIW.
The Andrew.
Old Feb 21, 2005 | 04:08 PM
pierrot le fou's Avatar
Not sure if this helps, but I have the 205/50/15 mx's on my 89 crx, w/ 15x6.5 rotas (don't know offset, sorry), and otherwise stock suspension. I also have the MX's on my 92 miata w/ 15x7 wheels (35 offset), Koni/GC's. No rubbing at all on either car. On 15x6.5 wheels, they stick out a lot more. On 15x7, they seem to fit tighter. Never made any actual measurements, but they do look wider than the 205/50/15 712's i used to have. The MX are almost as wide as my prev set of azenis (which did rub, when they were on my eg hatch).
I will be putting on another set of 205/50/15 on my ek w/15x7 (43 offset) wheels. I'm having the fenders rolled for that, since i'll be using 225/50/15 RA-1's as well anyhow.
Old Mar 4, 2005 | 02:52 PM
NoClassic's Avatar
I got the tires and they fit. They are a bit closer than the 712's but should be ok.
h8ted ek
Jan 14, 2009 02:10 PM
io_burn
Nov 2, 2002 02:02 PM
_Shadow_
Dec 21, 2001 10:43 AM
jared703
Oct 17, 2001 03:08 PM
ff-formula
Sep 18, 2001 09:47 PM
