help: my heat and air don't work
it's a 90 integra ls the heat and air just die i thought it was the blower motor and replace it still don't work i check the fuse and it's still good ?
Modified by 94_civicEx at 8:46 PM 2/17/2005
this is kinda off topic but how did u get the blower motor out ive got the bolts out and i can move the actual blower around but its up against the floor and i cant gte it out.i dont know what to do.ive got inspection at the end of the month help!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_civicEx »</TD></TR><TR><TD CLASS="quote">i not getting any air at all</TD></TR></TABLE>
I understand that. I'm saying you've got air in the coolant system. You need to bleed it.
how would bleeding my coolant system and change my thermostat help to have working air in my car?
i would bleed it if i'm not getting any heat but i don't even have air
i'm
i'm
g2ic.com will answer your questions. Just search blower motor or heater and you should be good. I think it mite be the resistor switch on the top of the blower box. Where did you find the fuse? Is it a fusable link?
preludesi93-arg
Dec 29, 2006 02:49 PM
