GLISTEN PC anyone?
Old Feb 17, 2005 | 10:56 AM
Mooneyes13's Avatar
Default GLISTEN PC anyone?
THis stuff is hot.
http://www.por15.com/product.asp?productid=246
GLISTEN PC
A Brilliant Two-Component Clear Coating
GLISTEN PC is a High Gloss, Rock Hard, Water-clear topcoat designed for spray or brush application over all metal surfaces, including highly polished aluminum and chrome surfaces. GLISTEN PC will not leave brushmarks, and will dry in less than one hour, but will take 3-4 days to reach maximum hardness.
When GLISTEN PC is first dry to the touch, it will appear to be very soft. Avoid touching it for several days until it becomes hard and tough. Accidental contact could damage the surface before full cure has taken place. Like many other coatings, GLISTEN PC is a MOISTURE-CURED coating, which means it is strengthened by exposure to moisture. It will never crack, chip, peel, or yellow, and is very flexible as well.
IDEAL USES: As a protective coating on aluminum wheels, chrome bumpers, marine railings, chrome or aluminum covers, grills, handles, ornaments, lights, etc
Modified by MoonRacer13 at 11:19 PM 2/17/2005
ax77
Aug 13, 2016 08:56 AM
cilvia
Oct 31, 2008 10:12 AM
cbstd
Jun 4, 2008 08:09 AM
ITR.#1446
Paint and Body
10
Feb 12, 2008 02:04 PM
ITR.#1446
Feb 7, 2008 03:41 AM
