Water to Air Intercooler Tank
Old Feb 17, 2005 | 10:11 AM
chrisgvr4's Avatar
Default Water to Air Intercooler Tank
I started fabricating the tank for my water to air intercooler the other day. It tucks nicely up in the passenger side front corner in front of the wheel. Method for getting the dimensions is pretty easy. I calcuated the rough cube I needed from the cubic inches in 3 gallons. Then I tooks some measurements so that it would fit in the spot I wanted it. Next I cut out cardboard rectangles and taped them up to fit and then test fit the tank on the car. It didn't quite fit due to a little sheet metal so I made a little cutout in the upper part of the tank. Now it fits nicely and ended up holding right at 3 gallons. Now I've got the dimensions to cut the pattern out of 1/8" aluminum sheet and weld together :D
Old Feb 17, 2005 | 10:13 AM
chrisgvr4's Avatar
Default Re: Water to Air Intercooler Tank (chrisgvr4)
Got a little further (time lapse posting)...
Tank is now tacked and partially welded. I still need the bungs and filler on the top from Summit (part# anyone?) before I weld the top on.
Test tank vs actual tank
Tacked up
Inside tacks
Weld closeup
Another closeup weld
Old Feb 17, 2005 | 10:37 AM
5STAR3's Avatar
Old Feb 17, 2005 | 12:01 PM
4drtegra's Avatar
thats awesome looking. I was considering doing the same for a turbo setup when i start it. What are you doing for the piping? COuld you explain in more detail how you are doing this? Thanks James
Old Feb 17, 2005 | 12:39 PM
chrisgvr4's Avatar
Default Re: (4drtegra)
I'm making the piping as well. This is just the water/ice reservior. Core is a PWR 6x10 fed by a gt42.
I'm not sure what you need explained better but if you clarify that I can post more info.
Old Feb 17, 2005 | 03:00 PM
4drtegra's Avatar
yeah sorry if i didnt explain well. i wasnt sure how to word it. The core is what i meant and how you were actually going to be cooling the air. Thanks and looking forward to some more pics when you get it done. James
Old Feb 17, 2005 | 06:23 PM
mrbsponge's Avatar
lookin tite keep us up on the progress
Old Feb 18, 2005 | 07:23 PM
Want2race's Avatar
Default Re: (mrbsponge)
Looks good.. You may want to put a slant on the bottom to a common drain just incase you ever have to wash out the tank.. Or maybe a removable fitting like a T piece
Old Feb 18, 2005 | 08:38 PM
chrisgvr4's Avatar
Default Re: (Want2race)
Yep there will be a drain on the bottom. Just haven't got that far yet
Old Mar 5, 2005 | 05:47 PM
chrisgvr4's Avatar
Default Re: (chrisgvr4)
Just a little update:
Received my bungs to weld on today so I'll be finishing up the project this week. It's fully welded except the top of the tank and the bungs so it won't be long.
Old Mar 5, 2005 | 06:04 PM
dk-fabrications's Avatar
where did you order the bungs from ??
Engloid's Avatar
OG Fabricator
Looks good.
I know it's too late on this project, but I have a suggestion for others, or the next time you make something like this.
Notice how your corners fit in a way that one overlaps the other...
If you make the inside edges of the metal meet, it makes a nice V shape on the outside that you can then fill with weld metal. It makes for a nicer fitup that's easier to weld.
Old Mar 5, 2005 | 06:33 PM
Default Re: (Engloid)
thats def a good point for a cleaner more even weld to line up each side to make a v and weld that up thats the way i do all my welds when i come into a situation like this
Old Mar 5, 2005 | 08:01 PM
chrisgvr4's Avatar
Ya good point Engloid. A couple corners line up like that but most don't. I needed to get this cut quick so I made the pieces a little too long to make them meet in a V. I'll try that in the next tank. Also the very inside corner of the "cutout" piece was damn hard to weld. I got it welded solid but it's going to take some more practice or maybe different lens's to get it really pretty.
Old Mar 6, 2005 | 10:44 PM
MR-MUGEN's Avatar
nice work
Old Mar 7, 2005 | 08:31 PM
chrisgvr4's Avatar
Default Re: (jdm92daintegra)
Got a little farther. Just a few more pieces and i'll be done. More bungs are on order and I need to pick a lid and get it done. The inside corner weld didn't turn out the prettiest but i was happy considering it was my first inside corner ever. Most important part, no leaks. lol
Chris
Old Mar 7, 2005 | 09:08 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid &raquo;</TD></TR><TR><TD CLASS="quote">Looks good.
I think I understand that, your talking about so the corner would not be a perfect 90 degree wrap around bend, more of a small gap missing ( basically a v point inward ) and once you weld it, it would be a 90 bend ? Like right now the weld sticks out a tad so its not really a true 90 bend. Am I making sense ?
Old Mar 8, 2005 | 05:12 AM
tony1's Avatar
Default Re: (90blackcrx)
Yeah, that's what Engloid is talking about. It makes a huge difference on how the weld looks when you do it that way. It puts the weld right on the corner rather than on one side and allows for easy penetration since you have a groove to fill.
Old Mar 8, 2005 | 05:37 AM
chrisgvr4's Avatar
Default Re: (tony1)
Any tips on how to do the inside corner better next time? The one on the cutout where three pieces all join? I stuck the tungsten out a little farther but it was still hard to get the torch close to the work on the very inside part. I have a limit supply of accessories but it's my work welder so they'll probably order more for me if I know what to ask for.
Old Mar 8, 2005 | 06:04 AM
tony1's Avatar
Just need some more practice, shouldn't need anything special to do that weld. It generally takes more heat for that weld, but no special cups or anything. Just a bunch of scraps and practice on them. I don't know of any tips to give on that or i would.
Old Mar 8, 2005 | 12:43 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisgvr4 &raquo;</TD></TR><TR><TD CLASS="quote">cardboard </TD></TR></TABLE>
Old Apr 18, 2005 | 02:07 PM
chrisgvr4's Avatar
Default Re: Water to Air Intercooler Tank (2point2)
Just an update. I got my order in from summit so I just need to punch out the cap hole and weld on the top. I'll post finished pictures before and after powdercoating.
Old Apr 18, 2005 | 06:09 PM
fulldragcrx's Avatar
i would reccommend pressure checking that before going thru with any other time consuming features u may have in mind, for that tank. hate to see ya powder coat it and it leaks and needs to be welded again
Old Apr 19, 2005 | 06:12 AM
chrisgvr4's Avatar
Default Re: Water to Air Intercooler Tank (fulldragcrx)
Thanks. I filled it up and it holds water. I doubt the tank is going to be under any significant pressure seeing as it's just a tank for ice and extra capacity. I powdercoat it myself at work so I can alway just blast it and redo it should anything be wrong.
Old Apr 21, 2005 | 06:38 PM
2spooled4u's Avatar
nice work post some picks of the set up when its done
