Crazy Tachometer
Old Feb 17, 2005 | 09:09 AM
samuraihakai's Avatar
Default Crazy Tachometer
Hey everyone. I have a 92 honda civic lx 4dr sedan. My tachometer goes nuts when I drive the car. This randomly occurs when ever it feels like it. I have had this problem before. Last year the same thing happened. Eventually my car started to go to zero rpm's and wanted to shut off. My distributor had died. I replaced it, however, months later I still have the same problem. Anyone have an idea what this could be?
Samurai Hakai
Modified by samuraihakai at 11:38 AM 2/17/2005
Old Feb 17, 2005 | 10:14 AM
Cory Matthews's Avatar
Default Re: Crazy Tachometer (samuraihakai)
you have a bad vss. Vhecicle speed sensor. brand new they run about 90 bucks you can find them used around 30-40. search the classifieds.
Old Feb 17, 2005 | 11:07 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by samuraihakai &raquo;</TD></TR><TR><TD CLASS="quote"> My tachometer goes nuts when I drive the car.
Last year the same thing happened. Eventually my car started to go to zero rpm's and wanted to shut off. My distributor had died. </TD></TR></TABLE>
So is this an engine or a tach problem? Does the RPMs of the motor fluctuate, or is it just the tach?
Old Feb 17, 2005 | 01:43 PM
doublejz's Avatar
Default Re: Crazy Tachometer (EX_AutoXer)
before you buy anything make sure its not a loose ground. Check your grounds and make sure they are clean and tight (frame rail, valve cover, thermostat). If everything looks good then what i would do is swap out your gauge cluster with a friends to see if thats your problem, before blowing money.
Old Feb 17, 2005 | 01:59 PM
Default Re: Crazy Tachometer (doublejz)
The rpms of the motor are fluctuating.
Battle2.0Eg
Honda Civic (2006 - 2015)
14
Sep 4, 2008 08:33 PM
FastAzzDA
10
Oct 25, 2006 01:53 PM
CRISIS
24
Jul 21, 2006 10:34 AM
sixtodc2
Dec 31, 2005 02:05 PM
del_parker
May 7, 2003 05:07 AM
