ITR motor is in and no check engine codes, but whats wrong!?? =(
Well, we put my buddies 99 JDM ITR motor in his 1998 Civic DX the other night and when we went to fire it up.
The car hardly runs for a second, then shuts back off.
Then when I gave it throttle, after starting it again. The motor hardly runs, misfiring VERY bad.
Im getting NO check engine codes.
Let alone, I have changed the oil,Plugs,Wires,Distributer, and even the Ecu
What could this be? This I must say is getting very frustrating
Can you guys give me any help or info as to "what" it could be?
Thanks for anything at <U>ALL</U>
Do you really need two threads on this? Stick to one, please.
https://honda-tech.com/zerothread?id=1152500
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">Do you really need two threads on this? Stick to one, please.
https://honda-tech.com/zerothread?id=1152500</TD></TR></TABLE>Yah, Im pretty desperate at this point
Did you really have to put me on blast like that?
I didn't "blast" you in any way. I simply pointed out you have two threads, and posted a link. If anything, I helped you out. I could have called you several names and all other sorts of "blasts" as you put it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">I didn't "blast" you in any way. I simply pointed out you have two threads, and posted a link. If anything, I helped you out. I could have called you several names and all other sorts of "blasts" as you put it.</TD></TR></TABLE>
poorman's type-r
Dec 17, 2005 10:30 PM
Collateral
44
Feb 18, 2005 08:18 PM
