Maint Reqr Light On!
What do you guys think is causing this?
Cooling System Flush with Recycled Antifreeze?
Battery Corrosion Package?
Mastercare Premium 4 cylinder tune up package?
oil leak detection?
These are my recommended tune ups!
oil leak detection?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1quickDC2 »</TD></TR><TR><TD CLASS="quote">Ok it worked but now the ABS light is on!</TD></TR></TABLE>
First check out this thread to pull and diagnose the code: https://honda-tech.com/zerothread?id=978933
Since you have a 95 GSR, I'm pretty sure that you have a system leak as discussed in this thread: https://honda-tech.com/zerothread?id=1136396
Also check the connection to your battery, it can be something as stupid as that. On my car the bolt got stripped and the abs wire came loose, threw a new bolt and nut on and bam fixed.
samyd25
Nov 14, 2013 02:42 PM
Blaze45
Mar 12, 2013 02:59 PM
