Maint Reqr Light On!
Old Feb 17, 2005 | 07:48 AM
sleevedgsr's Avatar
Default Maint Reqr Light On!
What do you guys think is causing this?
Cooling System Flush with Recycled Antifreeze?
Battery Corrosion Package?
Mastercare Premium 4 cylinder tune up package?
oil leak detection?
These are my recommended tune ups!
Old Feb 17, 2005 | 07:50 AM
rough_draft's Avatar
the light comes on after so many miles. It doesn'tmean anything. just reset it.
Old Feb 17, 2005 | 07:57 AM
sleevedgsr's Avatar
Default Re: Maint Reqr Light On! (1quickDC2)
reset ECU?
Got steps on how to do so?
Old Feb 17, 2005 | 07:59 AM
virusiidx's Avatar
no there's a button underneath the dash on drivers side, right next to your right knee, press and hold that button until it turns off.
Old Feb 17, 2005 | 08:03 AM
sleevedgsr's Avatar
On a 95 GS-R?
Old Feb 17, 2005 | 08:06 AM
sleevedgsr's Avatar
Ok it worked but now the ABS light is on!
sleevedgsr's Avatar
Bump any special button for that?
Old Feb 17, 2005 | 08:11 AM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1quickDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Ok it worked but now the ABS light is on!</TD></TR></TABLE>
First check out this thread to pull and diagnose the code: https://honda-tech.com/zerothread?id=978933
Since you have a 95 GSR, I'm pretty sure that you have a system leak as discussed in this thread: https://honda-tech.com/zerothread?id=1136396
Old Feb 17, 2005 | 08:16 AM
BLacK FirE's Avatar
Default Re: Maint Reqr Light On! (timmy8151)
Also check the connection to your battery, it can be something as stupid as that. On my car the bolt got stripped and the abs wire came loose, threw a new bolt and nut on and bam fixed.
samyd25
Nov 14, 2013 02:42 PM
Blaze45
Mar 12, 2013 02:59 PM
SlammedBlackGSR
Jul 5, 2006 10:45 AM
VTECisSeXY
Mar 18, 2005 11:15 AM
RHGSR01
Aug 13, 2004 02:45 PM
