CTR pistons in a B17 block
Old Feb 17, 2005 | 07:41 AM
xracerGS-R's Avatar
Default CTR pistons in a B17 block
i'm rebuilding my bottom block soon and was going to put in some CTR pistons...i've done search on these, but still don't have a solid answer...my question is will my b17 gsr rods go well with the ctr pistons? if not, what needs to be done to make it fit? and is it reliable..
Old Feb 17, 2005 | 07:44 AM
xracerGS-R's Avatar
Default Re: CTR pistons in a B17 block (xracerGS-R)
getting ready for the summer...advice anyone
Old Feb 17, 2005 | 09:01 AM
Jasper_db1's Avatar
There are two threads on this page that deal with this subject.
Old Feb 17, 2005 | 09:16 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xracerGS-R &raquo;</TD></TR><TR><TD CLASS="quote">i'm rebuilding my bottom block soon and was going to put in some CTR pistons...i've done search on these, but still don't have a solid answer...my question is will my b17 gsr rods go well with the ctr pistons? if not, what needs to be done to make it fit? and is it reliable..</TD></TR></TABLE>
I used to have a B17 in my hatch, in fact, its still sitting in the garage now. I had CTR pistons in it for a short while, so listen up.
Compression will be 12.4-12.5:1. I see you are in Sacramento, well, I am in the area also. Let me tell you, the ref will tell you to get lost if you try to smog it. The NOX levels will be rediculously high from the high compression. You might want to reconsider your piston choice.
If you still want them in your car, you need to have the rods machined. Remove 1mm of material from the sides of the eye and you will be good to go.
Old Feb 17, 2005 | 06:45 PM
xracerGS-R's Avatar
Default Re: CTR pistons in a B17 block (Hybrid93Eg)
damn....compression is going to be that high...i thought it was only going to be around 11 something...thanks
Old Feb 17, 2005 | 07:59 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xracerGS-R &raquo;</TD></TR><TR><TD CLASS="quote">damn....compression is going to be that high...i thought it was only going to be around 11 something...thanks </TD></TR></TABLE>
no, the Cspeed calculator is wrong. The CTR/ITR pistons come out of the hole, giving the engine a negative deck height. When you calculate this into the equation, you will come up with the real compression ratio. There is a stick at the top of the All Motor forum explaining how high the compression really is.
Old Feb 20, 2005 | 07:50 PM
xracerGS-R's Avatar
wat kind of piston will put my skunk2 stage 2 to its max...if ctr is not a good option
Old Feb 20, 2005 | 10:16 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xracerGS-R &raquo;</TD></TR><TR><TD CLASS="quote">wat kind of piston will put my skunk2 stage 2 to its max...if ctr is not a good option</TD></TR></TABLE>
Pr3's work very nicely in the B17. I ran some in mine before I sold the shortblock. Puts compression at 10.7. A nice number thats higher then stock, but not too high. If you wanted it higher, run a thinner headgasket or perhaps some flat faced valves.. Even a P72 head would bump it up to 11.0:1.
seifer
Feb 10, 2006 06:47 AM
arielmalespin
Jan 12, 2005 11:29 PM
KoRE
Mar 3, 2003 01:04 PM
IC x Prince
Jul 10, 2001 03:06 PM
