ITB for d-series
as far as i know nobody makes a bolt on kit it would have to be a fab job pick up last months issue of honda tuning and there is a diy article for a d series
and be for warned tuning is a biatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP »</TD></TR><TR><TD CLASS="quote">Jenvey does and they are the best. Contact Don Flores at DFE Enterprises 904-378-4480</TD></TR></TABLE>
I also have been looking around for a pre-assembled set.
Thanks SMSP
Thanks SMSP
you can make your own bolt on i did read it on honda tuning they use a gst turbo, aftermarket header for your d series motor, intercooler from anycar and blowoff valve.umm u have to cu your after market header custom weld bolt and the right mods cant explain i dont think i can do it either its confusing you can give it a try
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic712 »</TD></TR><TR><TD CLASS="quote">you can make your own bolt on i did read it on honda tuning they use a gst turbo, aftermarket header for your d series motor, intercooler from anycar and blowoff valve.umm u have to cu your after market header custom weld bolt and the right mods cant explain i dont think i can do it either its confusing you can give it a try</TD></TR></TABLE>
what are you talking about?
stan
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D »</TD></TR><TR><TD CLASS="quote">what are you talking about?
stan</TD></TR></TABLE>
I think he might be talking about the Budget Boost series that Greg Leone did.
Th ITB story that we did was in the Feb '05 issue of Honda Tuning. If you can afford jenvey, go that route, I would have if I could have.
