More Swapping questions... D15B7 for D16Z6
Old Feb 17, 2005 | 05:28 AM
Go-kartolddude's Avatar
Default More Swapping questions... D15B7 for D16Z6
Okay, I have read enough on here about swaps to know I can get the ecu working by running wires for the Vtec to engage, and that this will be an extremely easy swap, all things combined. My questions are as follows:
Should I chip my ECU first, for whatever gains that will get me?
What are those gains?
Is the z6 tranny (comlete z6 swap is out of an EX) better than the tranny on my B7?
I understand 3rd gear is a little long in the z6. I will be pulling the tranny on the z6 to change out the clutch, so if they can/need to be swapped, it can be done easily enough.
Also, are the drive shafts the same? (just replaced one side on my B7, if it will work, I'll just replace the other side and have a new set.)
What compression ratio will I possibly gain having the z6 head shaved .01? .015?
Will a Y8 metal head gasket get me any more compression in the z6 than the standard z6 head gasket? (Everything I have read says the metal one is better, I am simply trying to get an idea of how much compression change I am going to get out of all things combined).
From everything else I have read it should be down right simple, for one mechanically inclined. Thanks for the input.
Old Feb 17, 2005 | 06:49 AM
Default Re: More Swapping questions... D15B7 for D16Z6 (Go-kartolddude)
Old Feb 17, 2005 | 08:16 AM
No one knows?
Old Feb 17, 2005 | 08:29 AM
ATHFlsHatch's Avatar
don't chip your ecu,use the stock ex ecu, use the z6 tranny, axles will work from your b7
Old Feb 17, 2005 | 11:00 AM
jerbear!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Go-kartolddude &raquo;</TD></TR><TR><TD CLASS="quote">
no you should not, no gains on stock motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Go-kartolddude &raquo;</TD></TR><TR><TD CLASS="quote">Is the z6 tranny (comlete z6 swap is out of an EX) better than the tranny on my B7?
z6 tranny &gt; b7
z6/y8 has shortest gears of all sohcs
Old Feb 17, 2005 | 11:12 AM
Default Re: More Swapping questions... D15B7 for D16Z6 (jerbear!)
Cool, anyone have any info on the compression questions?
Old Feb 17, 2005 | 12:50 PM
No one increases compression ratios this way?
Old Feb 18, 2005 | 05:45 AM
mornin' bump
tabrubaker323
Jul 30, 2013 02:02 PM
krysted9354
Mar 23, 2009 07:19 PM
ek coupe
15
Feb 6, 2009 02:48 PM
mattie_96
Sep 6, 2006 02:12 PM
Red_ED8
Oct 10, 2005 10:58 AM
