CTR pistons On eagle Rods.
I was searching this subject and i seen that some people say it can be done and others say it cant.
In the post with people that said it can be done said that you had to install teflon clips or wrist pin locks. and you have to cut grooves into the pistons.
So where can i get some wrist pin locks and does anyone know of a good shop that can do this?
Also should i get Eagle H beam or Eagle I beam rods?
Motor Setup
LS block
CTR pistons OS
Eagle rods????
B16 Head
BC III + cams
Omni valvetrain w/supertech valves
43mm DIY ITB
RC 310 cc injectors.
walbro 255 pump
VAFCII switchin to Crome
AN-R header merge collector
Motor Setup
LS block
CTR pistons OS
Eagle rods????
B16 Head
BC III + cams
43mm DIY ITB
walbro 255 pump
By the time you have a machine shop cut the wrist pin clip grooves,you could have almost paid for a set of SRP's.If your going to use the ctr's then have the machine shop put some arp rod bolts in a set of ls rods.
Glenn
Glenn
eddiecut
Aug 5, 2003 08:58 AM
vtec69
Jun 17, 2002 09:41 AM
