Weird idle problem
Old Feb 16, 2005 | 08:24 PM
Aphelion's Avatar
Default Weird idle problem
I know everyone has an idle problem, and I've searched, but I couldn't find anyone with exactly the same problem I have.
Sometimes after I come to a stop after a long ride, the engine will dip down to ~300 RPMs, get rough, and then go back up to 700. I found a way to replicate the problem though - if I rev the engine to 5k+, then let off, it goes down to 300 for a few seconds (gets rough), then back up to 700.
Anyone have an educated guess what my problem might be?
Old Feb 16, 2005 | 09:17 PM
94oemcivic's Avatar
Default Re: Weird idle problem (Aphelion)
you can check the timing or on the throttle body there is a air fuel adjusting screw get the manuel for the car and it will tell you how to adjust and fix it pretty good
Old Feb 17, 2005 | 10:28 AM
kip0485's Avatar
a little hope for u Aphelion i have the same issue with my civic
Old Feb 17, 2005 | 02:45 PM
Aphelion's Avatar
Default Re: (kip0485)
thanks 94oem Kip if I get it fixed, I'll let you know how I did it :]
Old Feb 24, 2005 | 01:02 PM
delslowcoupeB16a's Avatar
could be your idel air control valve
Old Feb 24, 2005 | 01:33 PM
ian.'s Avatar
Default Re: (delslowcoupeB16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslowcoupeB16a &raquo;</TD></TR><TR><TD CLASS="quote">could be your idel air control valve
nope cause it would throw a code and iam assuming that you throwing any right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94oemcivic &raquo;</TD></TR><TR><TD CLASS="quote">you can check the timing or on the throttle body there is a air fuel adjusting screw get the manuel for the car and it will tell you how to adjust and fix it pretty good </TD></TR></TABLE>
you can check the timing but whatever you do don't touch the idle screw on the tb cause that's not your problem
Old Feb 24, 2005 | 02:24 PM
ReDHaTcHyGuy's Avatar
Default Re: (IC33)
The IAC could be dirty , take it off and check the screen in it , Don't go messing with ur idle screw on the TB if u don't have to ... its not a air/fuel adjustment,, it is preset from the factory and if no one has ever messed with it u should leave it alone... it is there to set ur idle.......... souns to me like the iac just might be dirty...check it out
Old Feb 26, 2005 | 07:41 AM
alizilla's Avatar
Default Re: (ReDHaTcHy97)
i had the exact same simptoms... after a rolling road ( for other reasons ) i found my idle problem to be the lambda sensor in the exaust, giving false O2 readings to the ecu
a qwick scrub with steel wool got it going again.. but i should realy recomend you replace it. in the uk there about £75 but u could get a non-honda aproved part for less.
ali,
kim_performance
Honda CR-V & Element
16
Mar 10, 2019 04:43 AM
Backk InTheDA
Jul 27, 2009 08:37 AM
91EX4dr
Dec 6, 2008 06:30 PM
95accordh22a
Mar 31, 2005 11:47 AM
