Who's still running Toda C's nowadays?
Old Feb 16, 2005 | 08:23 PM
itralex's Avatar
Default Who's still running Toda C's nowadays?
with new cams practically comming out every month now, I wonder how the many people are not jumping aboard the new cam bandwagon and are running the older high lift cams such as the Toda's and Jun's
if you're running either of these cams, post your setup and represent
Old Feb 16, 2005 | 11:49 PM
B20[Vtec]'s Avatar
i'm running toda c 2!but i dunno the setup cos someone set the camshaft for me,.Thanx!
Old Feb 17, 2005 | 08:35 AM
itralex's Avatar
Default Re: (B20[Vtec])
anybody else?
Old Feb 17, 2005 | 08:44 AM
CHEETAH's Avatar
Default Re: Who's still running Toda C's nowadays? (HypeR1004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HypeR1004 &raquo;</TD></TR><TR><TD CLASS="quote">with new cams practically comming out every month now, I wonder how the many people are not jumping aboard the new cam bandwagon and are running the older high lift cams such as the Toda's and Jun's
if you're running either of these cams, post your setup and represent </TD></TR></TABLE>
lol, don;t jump aboard jsut yet, I'm still a lover of jun and toda ... and the onyl one that I've seen thats very impressive is Endyn's bumpstix ... but can;t disclose details on that.
a few people that I help out still use spec Cs and I tell them to continue with them, high mileage tolerant jsut like stock billets.
jump aboard in a few years after people put 20-30k miles on the "new" cams
greg
Old Feb 17, 2005 | 09:33 AM
Black R's Avatar
25 Year Member
Yup, toda's grinds are still my favorite.
I'm running spec a's in my turbo car, and spec c's in my allmotor one.
And of course I like jun3/4 as well.
These are classics.
I'd like to do a spec c vs spec d vs jun 3 vs jun 4 cam test on my new motor one day...
Old Feb 17, 2005 | 09:52 AM
da'ee's Avatar
I would like to see how the Toda C's do again M22's and SKunk Pro 1's.
Old Feb 17, 2005 | 09:57 AM
Pondus's Avatar
Default Re: (HypeR1004)
I'm gonna run Toda C's on my 2,1 liter Tall deck build, hopefully will have it running in a few months.
Old Feb 17, 2005 | 10:03 AM
itralex's Avatar
Default Re: (Pondus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by answer3 &raquo;</TD></TR><TR><TD CLASS="quote">I would like to see how the Toda C's do again M22's and SKunk Pro 1's. </TD></TR></TABLE>
I have some first grind m22's that i can get ahold of easily.
but if i test them, it'll be in a 85mm bore, 12.5-12.7 ITR motor with a portflow head and hytech header
Old Feb 17, 2005 | 10:56 AM
littlebluecrx's Avatar
toda c's here
Jason
Old Feb 17, 2005 | 01:06 PM
Pondus's Avatar
Default Re: Who's still running Toda C's nowadays? (littlebluecrx)
Sweet!
Any details on the setup?
Old Feb 17, 2005 | 01:15 PM
clayton bigsby's Avatar
i run spec C's and made 205 whp with a stock B18c5 bottom end with jg intakemanifold retainers, toda springs, belt ,cam gears and oilpump gears with just a jdm header and a'pex exaust with a erics racing ecu and i bouce my **** off the rev limiter thats set at 10300
Old Feb 17, 2005 | 01:57 PM
Default Re: Who's still running Toda C's nowadays? (Pondus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote">Sweet!
Any details on the setup?</TD></TR></TABLE> https://honda-tech.com/zerothread?id=1151298
Old Feb 17, 2005 | 02:34 PM
JDM978's Avatar
im soon to run a b18c5 with toda c cam with alll toda head package complete with ctr pistons
Old Feb 17, 2005 | 03:04 PM
Scotty B's Avatar
JUn3's here....50 thousand miles on em...195WHP B16a2!
Old Feb 17, 2005 | 03:41 PM
B20[Vtec]'s Avatar
woh...
N/A B16A2 wif Jun3 gain 195Whp?amazing!
Old Feb 17, 2005 | 04:29 PM
The Tea-father's Avatar
i'm running toda C on my Stock b18c made 205hp
Old Feb 17, 2005 | 04:46 PM
itralex's Avatar
Default Re: (The Tea-father)
those are some pretty impressive numbers from all the Toda powered motors
lets some dyno charts and some time slips
i'll have mine in a couple of weeks when i get my block back from sleeving
B20[Vtec]'s Avatar
Woh!Crazy!
I Love TODA C!
Old Feb 17, 2005 | 06:53 PM
itralex's Avatar
so what cr are you guys at with the C's?
Old Feb 17, 2005 | 08:56 PM
SuperTwinz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HypeR1004 &raquo;</TD></TR><TR><TD CLASS="quote">so what cr are you guys at with the C's?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Tea-father &raquo;</TD></TR><TR><TD CLASS="quote">i'm running toda C on my Stock b18c made 205hp</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM978 &raquo;</TD></TR><TR><TD CLASS="quote">im soon to run a b18c5 with toda c cam with alll toda head package complete with ctr pistons</TD></TR></TABLE>
Old Feb 17, 2005 | 10:18 PM
Edgar's Avatar
I've been using Toda Cs for a long time already.According to the specs, Toda C intake valve closing is 52.5 degrees.The intake closing determines the max rpm which means that a later intake closing will achieve a higher rpm.Skunk2 stage3 intake closes at 52 degrees,Buddyclub spec 4 cams closes at 49 degrees...although these 2 cams have more duration than Toda C,I have seen consistent 10,200rpm on my B20 setup,with jenvy ITB and Toda headers to match.
Modified by Edgar at 7:05 AM 2/18/2005
Modified by Edgar at 7:24 AM 2/18/2005
Old Feb 18, 2005 | 12:26 AM
Pondus's Avatar
My setup will be about 12.2:1
Old Feb 18, 2005 | 03:46 AM
Tbone's Avatar
I change cams alot.. But I think my love willl always be with my Toda b's...It was the most fun street cam I had.. I can only assume the c's would be the same with alittle more kick after 6500. Greg S , you have a set of c's I can dyno?
Old Feb 18, 2005 | 06:23 AM
Edgar's Avatar
Default Re: Who's still running Toda C's nowadays? (Tbone)
Hi T-bone, I'll have to agree with you on that...Toda Bs were my fav too with my 1.6 setup...been using them in my first 3 years to my satisfaction.However, my friends(jun supporters) swear that Toda cams suck,can't feel the vtec crossover.
Is the BC4 cams really that good? As stated,they are meant for endurance race, but is it suitable for drag?
Old Feb 18, 2005 | 07:08 AM
Scotty B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20[Vtec &raquo;</TD></TR><TR><TD CLASS="quote">]woh...
N/A B16A2 wif Jun3 gain 195Whp?amazing!</TD></TR></TABLE>
LOL...maybe I was a bit unclear, Not a 195WHP gain. 195 whp total.....
