after fixing exhaust leak which was wastgate not fully on...
Old Feb 16, 2005 | 07:55 PM
Kirk@SyndromeAuto's Avatar
Default after fixing exhaust leak which was wastgate not fully on...
After i fixed my wastegate and put a new gasket on because it wasnt fully tightened. Anyways my car was quieter before I fixed it now it is loud as ****. I have a open dumptube but could that be the reason? it sounds like an exhaust leak even huger but that makes no sense cause I jsut fied the only exhaust leak. I currently have a stock GSR exhaust bolted up. My car also smokes a hella lot when I hit boost. If you didnt guess already I have a integra gsr 1999 with a drag kit on it. Im running a FMU and a Missing link right now until i get money for a ecu chipped and injectors + tuning. If anyone could guess why this is happenning it would be a big help. Thanx
Old Feb 16, 2005 | 08:14 PM
Archidictus's Avatar
Unceasing Measure
Default Re: after fixing exhaust leak which was wastgate not fully on... (Pitiful X)
What color is the smoke and at what rpm do you begin to hear the "exhaust leak"?
Old Feb 16, 2005 | 09:48 PM
Default Re: after fixing exhaust leak which was wastgate not fully on... (Archidictus)
right when i step on the pedal even in nutral. And also a **** load of smoke comes out like arround 6000 rpms on full load. I cant figure it out. It was fine before the shop and all they did was replace the gasket and i saw them do it and now its super loud. if you need a video I can make one.
Old Feb 16, 2005 | 09:51 PM
wantboost's Avatar
Who is Mr Robot?
the noise is the open dump. the smoke,well, that could be many things
Old Feb 16, 2005 | 10:01 PM
Default Re: after fixing exhaust leak which was wastgate not fully on... (wantboost)
the last turbo I had tho the dumptube was not that loud it was only loud when i got on it. this time its loud with a tap of the gas
salaamq
Dec 31, 2011 05:12 PM
allricedout
Mar 14, 2007 06:33 PM
r1de4life
Mar 2, 2006 09:42 AM
twisted_1
Aug 29, 2003 02:13 PM
