ABS Axles or Non-ABS axles for swap?
Old Feb 16, 2005 | 07:52 PM
j0nptw's Avatar
Default ABS Axles or Non-ABS axles for swap?
I searched but didn't really find anything that I needed to know. My ? is i just got my GSR engine for my swap, and now i need to get axles for it. My 94' EX has ABS, so my ? is should i get ABS axles and swap it in? or for around $60 less i can get some Non-ABS ones. if it was up to me i would probly just get the non-abs axles because it's going to be a summer car. I would just like to know what kind of work i would have to do to remove the ABS from it? ty
Old Feb 17, 2005 | 05:59 AM
93civicsedan's Avatar
Default Re: ABS Axles or Non-ABS axles for swap? (j0nptw)
Since your car has ABS I think you should get ABS axles.
Old Feb 17, 2005 | 06:02 AM
jdm123's Avatar
Default Re: ABS Axles or Non-ABS axles for swap? (93civicsedan)
yea it seems likes that would makes the most since but i dont really know either
Old Feb 17, 2005 | 06:41 AM
miahmouse's Avatar
I'd imagine you could just pull the fuse for abs but I honestly have no idea. but completely removing it would involve replacing all the lines from the prop valve on... honestly I'd keep the abs...
Old Feb 17, 2005 | 06:59 AM
rfeigley's Avatar
swap the abs ring over from your original axles, i do it all the time.just use a hammer and a punch, but don't hit too hard in the same place too many times, and it will come right off.
Old Feb 17, 2005 | 09:06 PM
j0nptw's Avatar
Default Re: (rfeigley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rfeigley &raquo;</TD></TR><TR><TD CLASS="quote">swap the abs ring over from your original axles, i do it all the time.just use a hammer and a punch, but don't hit too hard in the same place too many times, and it will come right off.</TD></TR></TABLE>
so your sayin i can take the ABS rings off my D series axles and put them on the Non-ABS B series axles and that will work?
Yes you can pull the fuse and ABS is no longer on, but you get a yellow ABS light on your dash and i'd much rather remove everything if i was gonna go non-abs.
Old Feb 18, 2005 | 10:12 AM
rfeigley's Avatar
yes, the outer joint is the same
DARIUSZ - DNPhoto
Transmission & Drivetrain
Aug 22, 2009 01:06 PM
00CIVICSITEIN
Mar 15, 2004 02:53 AM
EKRacer
Mar 14, 2004 05:46 PM
ILOVEGIRLS
Mar 27, 2002 08:36 PM
