Technical Help rough idle white smoke
Old Feb 16, 2005 | 07:20 PM
drastikchangez's Avatar
Default HELP PLEASE Technical Help rough idle white smoke
its a b20 motor low milage with an ls tranny
ok i changed the tranny oil
changed the oil
spark plugs
drove it and seemed fine
after about 10 min it bogged like it wanted to die. i drove it home turned it off
and when i tried to restart it it wouldnt. i changed the whole distributor and got it
to start but it idles bad and if i put my hand by the muffler i can feel the air and its white and smells like gas.
any help would be greatly appreciated thanks
update: i got home checked everything turned the car on it has a rough idle and if i put my hand by the muffler it wets it and it smells like gas really really strong and help please.
Modified by drastikchangez at 5:27 AM 2/17/2005
Old Feb 16, 2005 | 07:33 PM
mr.beeks's Avatar
Default Re: Technical Help rough idle white smoke (drastikchangez)
bad ignition cable sequense
1342
Old Feb 16, 2005 | 07:40 PM
i checked the sequense on the cables and there right
Old Feb 16, 2005 | 08:27 PM
Default Re: HELP PLEASE Technical Help rough idle white smoke (drastikchangez)
please help
Old Feb 16, 2005 | 09:36 PM
please someone
Old Feb 17, 2005 | 07:38 AM
virusiidx's Avatar
well since no one is replying might as well give it a try.
How's your compression? when you say you changed the distributer, did you change the rotor and cap?
Old Feb 17, 2005 | 09:58 AM
cnydc2's Avatar
Default Re: (virusiidx)
White smoke is not cool, check the comp. Is there any oil in your radiator or resivoir? Sounds like a possable bad head gasket.
Old Feb 17, 2005 | 09:12 PM
compression
180
180
162
165
yes i changed the whole distributor, cap and rotor
Old Feb 17, 2005 | 10:10 PM
virusiidx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drastikchangez &raquo;</TD></TR><TR><TD CLASS="quote">compression
180
180
162
165
yes i changed the whole distributor, cap and rotor</TD></TR></TABLE>
you have an ls? the compession isnt that bad, but also isnt that good. How much smoke is coming outta the tail pipe? or where is the smoke coming from?
looks like a possible small damage on the headgasket towards 3 and 4, but not bad, how's your coolant, oil?
Old Feb 17, 2005 | 10:25 PM
its a b20 motor
Old Feb 18, 2005 | 12:48 AM
WhiteGSR95's Avatar
could be a head gasket,, or bad rings on ure 3rd and 4th pistons. about the bad idle im not sure.. hmm
i just read the smells like gas part. after driving alittle does it still idle crappy at a stop?
Old Feb 18, 2005 | 01:12 AM
LsVtec98's Avatar
did you check your idle control valve?
Old Feb 18, 2005 | 06:00 AM
virusiidx's Avatar
if it smells like gas, check your fuel system right away, for any leaks, check the injector seals also.
Old Feb 18, 2005 | 09:47 AM
VTEC Visions's Avatar
White smoke may be from bad head gasket.
Old Feb 20, 2005 | 06:45 PM
Default Re: HELP PLEASE Technical Help rough idle white smoke (VTEC Visions)
ok the car is still idling pretty rough and i noticed gas coming from the
exhaust manifold. i looked at the injectors and noticed one was staying on
which i think that might be the problem if anyone has any other suggestions
let me know thanks.
E85B18
Jul 9, 2021 12:38 AM
93_luder
May 28, 2015 08:58 PM
Aradin
Nov 17, 2012 04:01 PM
drastikchangez
Mar 29, 2005 12:02 PM
mike5809
May 25, 2003 02:40 PM
