Engine Torque Specs
Old Feb 16, 2005 | 11:36 AM
v930's Avatar
Default Engine Torque Specs
I was wondering if anyone knew a good website with torgue Specs for like the head bolts, crank, rod, cam, and all other major bolts. but mainly here is a list.
Head bolts
camshaft bolts
The cradle that hugs the crank in the middle
the rod bolts
intake manifold bolts / exuast manifold bolts
oil pan bolts
and anything else i should know when building the motor back together.
Thank you
Old Feb 16, 2005 | 01:21 PM
v930's Avatar
Default Re: Engine Torque Specs (v930)
ne one
Old Feb 16, 2005 | 01:30 PM
purplegsr's Avatar
The Helms manual shows all the torque specs you need. You could buy a paper copy, or if you have time, print out the necessary pages from a pdf version of the manual, as seen here:
http://www.redpepperracing.com...a-FSM
Old Feb 16, 2005 | 08:22 PM
v930's Avatar
Default Re: Engine Torque Specs (purplegsr (Exospeed))
Def. thanx alot bro, Greatly appreciate it.
spoolinegsr
Jun 6, 2007 08:41 PM
eortizr
Aug 23, 2005 10:08 PM
v930
Feb 16, 2005 11:38 AM
92-LS-Civic
Oct 7, 2004 07:47 AM
Guru Designs
Jul 8, 2004 06:08 PM
