Four-oh-four's, what exactly is the "nasty idle"?
Old Feb 16, 2005 | 08:01 AM
jeef84's Avatar
Default Four-oh-four's, what exactly is the "nasty idle"?
I've heard of stock LS's spanking with the Crower 404's, but I've also read that the idle is really nasty with the wild cam setup. Is "nasty" supposed to be like a rumbling sound? Or a surging idle or what? I'm trying to see if it's something I can live with before I drop them in my LS.
Old Feb 16, 2005 | 08:51 AM
Tuesday Club's Avatar
Default Re: Four-oh-four's, what exactly is the "nasty idle"? (jeef84)
also very curious
Old Feb 16, 2005 | 09:54 AM
phatrick2332's Avatar
2 words, big block
Old Feb 16, 2005 | 10:04 AM
jdmcx's Avatar
i think it is a surging idle
Old Feb 16, 2005 | 12:22 PM
erebunicrx's Avatar
Default Re: Four-oh-four's, what exactly is the "nasty idle"? (jdmcx)
https://honda-tech.com/zerothread?id=1034855 the last post of the thread i posted the sound link. its not mine.
Old Feb 16, 2005 | 12:51 PM
4piston's Avatar
Default Re: Four-oh-four's, what exactly is the "nasty idle"? (erebunicrx)
The idle isn't bad at all. Its a little lumpy at startup but once its warm it is very tame. My little sister has them in her daily driver and hasn't ever had any problems.
Old Feb 16, 2005 | 02:20 PM
Eclypz's Avatar
It also has to do with how much overlap you're running.
My car didn't idle without my foot on the throttle for cold starts.
Once it warms up, the idle is lumpy, surging from 1100rpm to 300rpm
I was running an overlap of 4.
Modified by Eclypz at 4:33 PM 2/16/2005
Old Feb 16, 2005 | 03:32 PM
PirateMcFred's Avatar
Default Re: (Eclypz)
This sound clip is not of 404's but it is of large H23A1 cams(quicktime format):
right-click, save as
But illsutrates the point of a "nasty," "lumpy" or "lopey" idle. This is a 1000 rpm idle.
Pirate
Old Feb 16, 2005 | 04:07 PM
IN VTEC's Avatar
How much idle at vacuum was the motor pulling on the B18B's?
What are you guys using for injectors and engine management?
Old Feb 16, 2005 | 05:21 PM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eclypz &raquo;</TD></TR><TR><TD CLASS="quote">It also has to do with how much overlap you're running.
Modified by Eclypz at 4:33 PM 2/16/2005</TD></TR></TABLE>
Same here
Old Feb 16, 2005 | 11:44 PM
jeef84's Avatar
I can definitely deal with that. It's not sleeper by any means, but I wouldn't mind the extra power.
simon.vada
Sep 23, 2018 04:42 PM
Run Away
Mar 11, 2006 05:08 PM
Hyaboosta
Jul 13, 2005 02:14 PM
